Username Post: '56 3-Speed Overdrive Trans.        (Topic#354768)
George56
Loc: Miami, Fl
Reg: 03-16-16
01-08-19 03:55 PM - Post#2756913
I have a Bel Air Convertible with the X frame.My question is: Do you have to remove the Overdrive from the tranny to get the transmission out of the car?
George 56
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-10-19 03:46 AM - Post#2757011
    In response to George56
The Muncie 318 3 speed is the same length as it's cousin, the Muncie 319 overdrive transmission. You really don't even want to think about trying to separate the OD from a transmission while it's still in the car. I currently have two of these Muncie 319 speed with overdrive transmissions, AND a couple of NEW, Hurst shifters for both the Muncie 318 and 319 transmissions available. I am Butch/56sedandelivery.
01-10-19 05:42 AM - Post#2757016
George56
Loc: Miami, Fl
Reg: 03-16-16
01-10-19 09:25 AM - Post#2757039
I found out today that you can remove the OD Trans. without removing the overdrive. Fixed the leak and reinstalled it and everything works fine. Thanks for answering.
George
Execution time: 0.052 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:36 AM
