Username Post: 67 coil springs        (Topic#354749)
hdchevroletusa
Reg: 11-15-13
01-07-19 07:53 AM - Post#2756775
Wow, did I ever step into something that's over my head!
Changed coils on my 61 Bubbletop and my 67 Camaro. No problems.
The 67 is a different animal. The single bushing lower control arm has different geometry and I can't compress the spring enough to get it at the correct angle to seat properly.
The Service Manual says to disconnect the bushing from the frame and use a special steel rod and a 5" block of wood cut at a special angle to jack up the control arm.
Need some help. Any advice?
THANK YOU!!!!
mjc1
mjc1
Loc: Burlington Ontario Canada
Reg: 09-15-04
01-07-19 03:30 PM - Post#2756806
    In response to hdchevroletusa
I've always just used a 4 hook/threaded rod spring compressor on the bench, and very carefully (with the spring secured), slowly worked it to compression. It is a scary job for sure, but if you fit the compressor like designed, use some never seize on the threads and go slow (no airtools allowed!), you'll get the spring (potential bomb) to the point you can get it in. The 4 arm compressor will, properly installed, bring the spring into that proper arc required to bring the arm pocket up to meet it correctly. That arc imop is key. Just figure it out how the pigtails of the spring fit in the pockets before orienting the compressor for that correct arc. It takes some time to figure it out, but it has worked every time for me.
I've always just disconnected the upper ball joint and strut rod and let the arm and spindle hang down supported on a trolley jack. Use a strong bungy cord or black strap attached to the top of the wheeltub, connected to the spindle to keep it from flopping around when disconnected. Cheers, Mark.
1967 Grande Parisienne 4DR HT
My Flickr page
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
01-07-19 08:32 PM - Post#2756833
    In response to mjc1
ONLY use a heavy-duty INSIDE spring compressor. NEVER use an outside spring compressor or one designed for struts.
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
Edited by BigDogSS on 01-07-19 08:32 PM. Reason for edit: No reason given.
mjc1
mjc1
Reg: 09-15-04
01-08-19 09:46 AM - Post#2756878
    In response to BigDogSS
Absolutely BigDog, the inside type only!
My Flickr page
9Teen67Biscayne
9Teen67Biscayne
Loc: OK
Reg: 07-29-16
01-08-19 12:38 PM - Post#2756890
    In response to mjc1
yup - inside... until running across these springs I was only afraid of 2 things - angry women and cockroaches... you can add 67 B body front spring R &R to that ...
Tim Saepe Expertus- Semper Fidelis- Fratres Aeterni
"He must be the stupidest sonofabitch alive - but he sure is fast." - F. Gump
mjc1
mjc1
Reg: 09-15-04
01-08-19 02:44 PM - Post#2756904
    In response to 9Teen67Biscayne
Also, when compressed. Handle it with the care as if it could go off at any time. Some will strap or chain it as protection. Don't drop or bang it around. Make 100% sure the hooks are on correctly and make sure none of the compressor is damaged in any way. I'm no mechanic or expert, so you must consider doing this entirely at your own risk.
Here's a old image I found from years back showing what I felt was a good hook orientation that will get you that arc you'll need. You can see that by positioning the short hooks this way, you'll get an inside arc forming to that side.
My Flickr page
Rick Dorion
Rick Dorion
Loc: Ulster County, NY
Reg: 09-21-12
01-09-19 04:57 AM - Post#2756945
    In response to mjc1
Great picture! Wish I had that when I did mine. I've done plenty of early camaros and started questioning my skills on this job on my 67 Bel Air.
1967 Belair - perfect floor, frame and pinchwelds. Oh boy.
65_Impala
Reg: 12-29-02
01-11-19 05:51 PM - Post#2757156
I dropped the big screw of the spring compressor through the shock hole at the top and only used the bottom half. Just pulled the spring up enough that it would clear the arm and start into the pocket. I had to use a ratchet strap to pull it towards the inside of the car a bit. Once it was started on the lower arm spring pocket then I just jacked it up the rest of the way until the suspension would go together. A lot less compression is needed from the spring compressor then trying to compress it all the way so the suspension would go together using just the compressor. To me, the less tension and the quicker I can get the spring from being held by the compressor, the better.
Did the same thing with a C3 Corvette, but didn't need the ratchet strap.
mjc1
mjc1
Reg: 09-15-04
01-12-19 09:56 AM - Post#2757197
    In response to 65_Impala
Thats a real good method going through the top shock hole. But the big thread of my 4 hook won't pass though it. It's too big. Suppose you could just use a smaller heavy duty rod.
My Flickr page
hdchevroletusa
Reg: 11-15-13
01-15-19 01:29 PM - Post#2757473
    In response to mjc1
Thanks for help guys. Working on it now. The biggest problem was the spring compressor I rented from Auto Zone only had hooks at the top. It used a plate/fork at the bottom instead of 2 hooks like at the top. Need to get the correct type of compressor. Arching the spring in the correct direction is key too.
Hopefully all goes well. I'll let you know.
Thanks again!!
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
01-16-19 06:02 PM - Post#2757574
You should be able to use that type of spring compressor with the plate.
Edited by BigDogSS on 01-16-19 06:03 PM. Reason for edit: No reason given.
Execution time: 0.254 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:16 PM
