Username Post: Clutch        (Topic#354732)
Rboxcar
Reg: 01-02-19
01-05-19 12:28 PM - Post#2756646
Clutch not fully disengaging in neutral
01-05-19 03:29 PM - Post#2756657
    In response to Rboxcar
Welcome to ChevyTalk. Please post your question in the correct forum below. Browse the forums to find the correct one.
Also provide what you are working on. IE Year, Engine Transmission and any other vehicle info.
29-41, 42-48, 49-54 Moderator
rcr3
rcr3
Loc: MANHEIM PA. U.S.A.
Reg: 11-24-02
01-06-19 05:42 AM - Post#2756688
OY !!!
'67 Camaro survivor
'06 Z71 Sierra Ex Cab
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
Rboxcar
Reg: 01-02-19
01-06-19 07:11 AM - Post#2756691
1955 Chevy. 327. Muncie 4 speed. Clutch not fully disengaging with pedal out and in neutral. Car moves a little and whirring sound
01-06-19 06:58 PM - Post#2756740
You need to adjust the clutch linkage.
Rboxcar
Reg: 01-02-19
01-06-19 08:47 PM - Post#2756748
    In response to Rick_L
I've adjusted it both ways. No difference!
craig32
Loc: PA
Reg: 08-05-07
01-07-19 05:35 PM - Post#2756810
If the pedal is out, the clutch is engaged. Depressing the pedal disengages the clutch. If it is moving with the transmission in neutral, it sounds like a transmission problem.
01-07-19 06:55 PM - Post#2756820
If the clutch won't disengage, the rod from the z-bar to the clutch fork needs to be adjusted longer.
You also need the correct clutch fork, correct length throwout bearing, and for everything else in the clutch linkage to be correct.
One thing that can happen on 55-57 clutch linkage is that the splined lever that attaches to the clutch pedal shaft can slip. You'll have to fix that to get the clutch to disengage if that's the problem. This lever is up under the dash.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-09-19 08:46 AM - Post#2756952
Appears from your description that the flywheel is in contact with the clutch disc (with the pedal 'out') as it should be. But it is slipping. Also, if your car is 'moving' while 'in neutral', you are NOT actually 'in neutral'; the car MUST be in gear to move. Two problems (or more).
The first if not solved by adjustment, is likely due to broken, wrong, or improperly installed parts. Throw out bearing? Clutch fork? Z bar? Push rods (upper and/or lower)? Pedals?
The second may be a shifter problem. Again, if not solved by proper adjustment/alignment, caused by broken, wrong, or improperly installed parts.
In the condition you describe (moving while in neutral), the mainshaft of the transmission is rotating, AND so is the countershaft. In 'neutral', that does not happen. If not the shifter, I would start by removing the cover and see what's going on.
I've attached some info you may find helpful. I've attached Hurst info because that is what I have. You did not say what shifter you have.
Pete
Attachment: muncie_manual.pdf (237.4 KB) 11 View(s)
Attachment: hurst_install_inst_huu-3733163.pdf (60.43 KB) 11 View(s)
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
01-16-19 09:42 PM - Post#2757580
    In response to japete92
I had a customer who had a Muncie 4 speed in a 64 Chevy. He said the car wanted to move even though the shifter was in neutral. It turns out the bearings were so loose that it allowed the input shaft to move forward and the main shaft to move back and the 4th gear synchro keys slipped out of the slots in the brass ring and pushed the brass ring against the input synchro cone and would make the car creep. This might be your problem.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
Execution time: 0.087 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:50 PM
