Username Post: Electrical Problems        (Topic#354721)
ayelander
Platinum Supporting Member
ayelander
Reg: 12-07-18
01-04-19 03:08 PM - Post#2756572
My 63 has been starting with no problem and I keep a trickle charge on it. Typically my Dakota Digital instrument registers 12v as soon as a turn the key to on. Went out this AM and noticed that the gauge was reading less that ~2-4v when I turned it on and then is just "clicked" when I tried to start it. Any ideas?
Ayelander
1963 Impala SS, 500 HP, EFI 383 Stroker, Tremec 6 Speed Manual Trans
1974 Corvette, 454 cu in, 4 Speed Manual
1951 Chevy 3100 Truck, Stock
2016 Chevy High Country, Diesel, Dually
del.impala
Loc: delaware
Reg: 04-13-11
01-04-19 03:13 PM - Post#2756574
    In response to ayelander
Battery posts have to be surgically clean,check grounds on motor,radiator support ground. Could be the battery just gave up the ghost.
ayelander
ayelander
Reg: 12-07-18
01-04-19 03:18 PM - Post#2756575
    In response to del.impala
Should have mentioned that both batteries read 12 volts.
Ayelander
ayelander
ayelander
Reg: 12-07-18
01-04-19 03:28 PM - Post#2756577
Cable terminals are "surgically" clean. I will check on the Engine ground. Is it possible that my alternator is bad? It is regulated internally for voltage but would my gauge be reading that drop?
Ayelander
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
01-04-19 05:35 PM - Post#2756584
Take a load test on battery ,I just went through this on my Silverado. The battery read 12.5 volts but with a load it dropped down to 10, checked after load test 12.5 + volts.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-04-19 06:14 PM - Post#2756589
    In response to 69_BOWTIE
My 64 will do the same thing every now and again. I've not replaced the wiring harness and the plastic clips get warm at the fuse block at the fire wall. I can wiggle mine just enough to make it crank right up. I took it all a part and cleaned up all the connections and reinstalled, it will do fine for weeks, months,days you never know. Thoes plastic clips get weak over time and don't keep it good and tight.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
ayelander
ayelander
Reg: 12-07-18
01-04-19 07:07 PM - Post#2756592
    In response to Andy4639
I'll try the load test and wiggle everything.
Ayelander
ayelander
ayelander
Reg: 12-07-18
01-05-19 08:29 AM - Post#2756622
Put my glasses on and my Dakota Digital gauge only goes as low as 9v but I did notice it has a digital warning for low voltage and it was counting down ...8.5, 8.4, 8.3 etc. went into the sevens and turned the key off. Any clue as to why it would act this way?
Ayelander
01-05-19 08:32 AM - Post#2756623
voltage drop test works well. clamp together battery terminals suck. lots of grease on the battery terminals will keep the corrosion off after they are removed, surgicaly cleaned all over, and clamped on tight, then you grease it. i know it looks ugly but you cant wipe off corrosion. those felt washers dipped in oil work pretty good too. that spray on terminal protector crap is crap. it looks pretty but its crap. ground should go directly to block. big battery cables work better than 4 or 6 gauge skinny cables......as for the gauge, it sounds like a dead battery
Edited by bobb on 01-05-19 08:35 AM. Reason for edit: No reason given.
ayelander
ayelander
Reg: 12-07-18
01-05-19 09:53 AM - Post#2756628
    In response to bobb
Is the Drop Test something I have to take the batteries out and take them to an auto parts store.
The reading across them reads 26.6 volts (I have two batteries) and the date stamp on them is 11/17 and they are a premium (auto craft gold) battery. Terminals are fine.
Ayelander
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
01-05-19 10:12 AM - Post#2756630
are you sure your trickle charger was working and plugged into the wall? If it went bad or wasn't plugged it it might drain the batteries.
ayelander
ayelander
Reg: 12-07-18
01-05-19 01:53 PM - Post#2756655
    In response to turbo38s10
Yes. It is one of those that tell you exactly what its doing and its keeping up nicely. The batteries are mounted in the trunk and the PO told me there is a disconnect somewhere between there and the engine. Its got to be something simple.
Ayelander
01-06-19 12:46 AM - Post#2756682
hard for me to explain a voltage drop test. you need a volt meter. i would suggest a you tube search..............reread evrything. seems that you have a bad connection. find that cut off switch.
Edited by bobb on 01-06-19 01:11 AM. Reason for edit: No reason given.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
01-06-19 06:16 AM - Post#2756692
If you are going to keep your batteries in the trunk (since you have two, I imagine you would) I suggest contact Mark from M.A.D. Enterprises and ask him how his "New System" can help your car. He has a website with a bunch of research you can read as well. MadElectrical.com. Good dude and very knowledgeable about our cars.
How long have you had the car prior to these issues coming up? Have you made any changes recently?
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
Edited by kingkreeton on 01-06-19 06:17 AM. Reason for edit: No reason given.
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
01-06-19 06:54 AM - Post#2756693
How are your batteries connected together?
You mention they read 26.6 volts. If so then they are connected in series which is incorrect and will cause lots of problems including damage to gauges.
Connecting them in parallel does not increase voltage but increases cranking capacity.
Please verify how they connect and let us know.
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
ayelander
ayelander
Reg: 12-07-18
01-06-19 02:00 PM - Post#2756724
    In response to kingkreeton
I have only had the car for two weeks or so and am still learning it. It ran pretty sweet when it first got here. I fiddled with the electrics today and it finally started right up. Ran like crap but it started. Did a retune with the EFI and it seemed to run smoother. Go figure. We will see what tomorrow brings.
Ayelander
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
01-06-19 03:47 PM - Post#2756729
Is the car still using the original fuse box and wiring system? I'm sure there as been additions due to your EFI system but I'm curious if the electrical system has been updated with a more modern wiring system?
Shane
64 Impala SS:
4 Speed Muncie
ayelander
ayelander
Reg: 12-07-18
01-06-19 07:33 PM - Post#2756746
The car has been totally rewired with modern touches. That includes new fuse panel and something else that looks like a fuse panel (still researching that one)
Ayelander
Edited by ayelander on 01-06-19 07:36 PM. Reason for edit: No reason given.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
01-07-19 04:09 AM - Post#2756764
OK, well that is good. Maybe you can find a brand name of the electrical system installed so you can download a wire diagram. You will never know when that might be useful in the future.
Shane
64 Impala SS:
4 Speed Muncie
ragtp66
ragtp66
Reg: 12-09-07
01-08-19 08:22 PM - Post#2756933
disconnect your ground battery cable connect a test light directly to the battery and the other end to the battery cable. Is the test light lit? If yes start pulling fuses one by one until the light goes out. Now you have narrowed it down to which circuit is the source of your problem. Be sure to close the door or disable your dome light so that it is not on.
Toys:
1987 Sea Ray Pachanga 22
shoeboxpaul
shoeboxpaul
Loc: New Freedom, PA
Reg: 08-15-16
01-14-19 09:44 AM - Post#2757337
Check the obvious first- that would be loose alternator belt. A loose belt can spin the alternator just enough to show everything working while the engine is running but, not fast enough to replenish the battery. Over a period of time the battery is drained. Deflection is one test and the other would be to turn the alternator pulley - does it turn the belt? If not, it is loose. The belt might not necessarily show any wear. You would be surprised how many alternators were sold due to loose belt.
The other obvious thing is to see if the battery connections are clean.
Edited by shoeboxpaul on 01-14-19 09:46 AM. Reason for edit: No reason given.
ballencd
Loc: Columbus, NC
Reg: 01-09-19
01-14-19 10:49 AM - Post#2757344
    In response to shoeboxpaul
Put a meter across the battery with the engine not running. You should get between 12-12.5 volts. Turn on the headlights.....how far do the volts go down? If your battery is good then the volts should stay pretty close to the 12-12.5. If it is bad or discharged then it will go way down like 6-10 volts....When the engine is running you should get 13-14.5 volts across the battery indicating that the alternator is charging properly. Sounds to me like a bad battery or a bad trickle charger.....or you have a bad connection somewhere.
The 26 volts you are reading concerns me because they should be in parallel not series for most applications and should read 12 not 26.
G. Baker
Loc: Ontario Canada
Reg: 12-18-15
01-14-19 01:49 PM - Post#2757365
Beautiful car. I had a '63 SS white Ragtop in blue/blue. Put in a 400/409 and replaced several trannys and a diff for my trouble!
Check to see if you have left under dash lights/glove compartment on or trunk lid open slightly. When you shut it off make sure brake lights are off which could mean a fault in the Alternator or brake light switch. I never needed a trickle charger but do now on my XLR. Check Starter ground if it has one and of course engine ground.
ayelander
ayelander
Reg: 12-07-18
01-14-19 06:46 PM - Post#2757390
    In response to G. Baker
The car is currently running. Trying to repeat the problem with no luck. I hate these "Phantom" problems.
Ayelander
ayelander
ayelander
Reg: 12-07-18
01-15-19 05:57 AM - Post#2757429
For those that wonder about my batteries. Series or Parallel?
Attachment: IMG952429.jpg (208.9 KB) 8 View(s)
Ayelander
Stittville Ed
Reg: 01-10-16
01-15-19 06:01 AM - Post#2757432
Nice choice on the cable size.
How did you do the Grounds?????
Some of the Street Rod people try using the frame for a ground conductor and it creates all kinds of problems.
ayelander
ayelander
Reg: 12-07-18
01-15-19 08:12 AM - Post#2757444
    In response to Stittville Ed
Still trying to get under it. Its new so I dont know alot about the electrics.
Ayelander
junky
Loc: Northeast CT
Reg: 06-27-10
01-15-19 01:27 PM - Post#2757472
I would suggest that you get a negative cable that has the crimped on battery connector, instead of the repair connector that you have on the left battery. Eventually, those connectors cause problems for a variety of reasons. I would only use one as a quick repair to get home, where I could fix the battery connection properly.
ayelander
ayelander
Reg: 12-07-18
01-15-19 02:16 PM - Post#2757475
    In response to junky
Ayelander
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-15-19 04:47 PM - Post#2757495
Parrlel batteries give you 12 volts but doubles the amp hrs for starting and anything that depends on the battery to run as the radio are wipers head lights.
So you doubled your run time if the car is shut off.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Execution time: 0.098 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:49 AM
