Username Post: offset blazer rearend        (Topic#354710)
49betty
Reg: 12-01-18
01-03-19 06:47 PM - Post#2756508
Hello. Asking anyone if the offset of the driveshaft on a 4wd Blazer S10 rearend is an issue when using it to convert to an open driveline. It seems to be about 1 inch off center. Im putting it behind a newer 3 on the tree transmission with a 261 inline. 3.42 gears I believe.
Bel Air kiwi
Deceased Member RIP
Bel Air kiwi
Reg: 04-24-14
01-04-19 12:19 AM - Post#2756532
    In response to 49betty
Hi Betty49, Congrats on finding a 261. Have a think about putting the S10 5 speed floor shift behind that engine and it will really respond well.
The three-speed manuals are one of the features that really date our cars and hold them back in modern traffic. Although the 5 speed is floor change and does require some adaption it really brings these old cars alive.
Bendix brakes, 53-4, steering box, electronic ignition, a shock absorber x-member and more gears are the top five improvements for these cars in six-cylinder form.
Cheers Kiwi
49betty
Reg: 12-01-18
01-04-19 05:18 AM - Post#2756538
    In response to Bel Air kiwi
Thanks for those thoughts. Im sure it is good advice about the 5 speed. Ive actually got a 5 Speed behind a 230/250 in a 1950 5 window that is my going to town for coffee truck and it is fun. Ive put disc brakes on the front of the car and I kind of liked the idea of keeping the 3 on the tree. What exactly is the X member shock absorber?
49betty
Reg: 12-01-18
01-04-19 05:24 AM - Post#2756539
Also I might be able to locate a 53-4 steering box. What is the benefits of that? Is it power or just easier/more leverage steering? Thanks, Kiwi, for any advice.
eplantage
Loc: Southern MN
Reg: 03-15-04
01-04-19 05:48 AM - Post#2756541
It involves adding a crossmember between the frame side rails to attach the top of shock absorbers to rather than the factory floor mount.
Age: 65 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
49betty
Reg: 12-01-18
01-04-19 06:12 AM - Post#2756543
    In response to eplantage
Oh yes, I remember reading about that in these posts somewhere. Thanks. Would it be possible for you to direct me to a picture of that cross member. No worries if you cant. I don't have the computer talents to deal with pictures.
2blu52
2blu52
Reg: 03-12-02
01-04-19 06:58 AM - Post#2756544
The parts in the 53/54 steering box are interchangeable in the older box, but all parts must be used. No power steering with the standard box but 53 was the first year power steering was available. The benefit of the later model box is it uses bearings instead of bushings.
THOMAS JEFFERSON
01-04-19 08:13 AM - Post#2756546
Chevs of the 40's sell a kit for it.
29-41, 42-48, 49-54 Moderator
eplantage
Loc: Southern MN
Reg: 03-15-04
01-04-19 08:28 AM - Post#2756547
here is an example from 40grit's 53 convertible build.
lobucrod
lobucrod
Loc: Springtown Texas
Reg: 10-01-07
01-04-19 09:10 AM - Post#2756554
The offset is no problem at all. Many vehicles have more offset that that. Some offset either side to side or up and down is beneficial anyway. It allows the rollers in the ujoints to work around some and not stay in the same place which would cause the rollers to wear into the u-joint trunions more.
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
01-04-19 12:10 PM - Post#2756561
    In response to lobucrod
I went from a 50 box to a 54. It is better, for sure, but there are also ways of using this stock front end with power steering. An astro van box, early Camaro MANUAL steering pitman, and a 1" model A ford pitman ball allow you to use a power steering gear. fabricate brackets to mount, or pay $1000 on line for a kit if its still available. Also, a bearing in the end of the stock column and a rag joint and your good to go. I havent done this, i am sitting on a camaro clip
Congrats on the 261!
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
01-04-19 06:14 PM - Post#2756580
    In response to drew1987
Forgive me for being so vain but I just had to update that picture of my shock crossmember.
Just Slightly Abrasive
49betty
Reg: 12-01-18
01-04-19 06:35 PM - Post#2756583
Thanks for the picture of the cross member and all the ideas. I think I can locate a later steering box so I may try that. How does the shock absorber cross member improve the car. Must be an obvious answer that I cant see. I wish I had found this forum earlier. There is a ton of good information among all you guys. Thanks again.
40grit
40grit
Reg: 07-08-13
01-04-19 06:56 PM - Post#2756586
Three things actually.
First, The crossmember removes the vibration being transferred to the body floors and isolates it somewhat in the chassis.
Secondly, most early Chevy's have the shock mounts cracked out. The sheet metal mounts would work harden and crack out over time.
Thirdly, a properly built crossmember will not flex as much and will enable the shock to better function.
Edited by 40grit on 01-04-19 06:57 PM. Reason for edit: No reason given.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-04-19 06:58 PM - Post#2756587
Don't forget, the 53-54 steering column/box will get you integral turn signals, AND is about an inch shorter, to give you more "belly room". Dang, I miss my 51 Bus Coupe! I am Butch/56sedandelivery.
49betty
Reg: 12-01-18
01-05-19 11:40 AM - Post#2756636
Hi Butch! I can always use more belly room! Do you have to use the whole column or can you just swap the guts out of the steering box. Im not sure of the quality of the donor steering box/column. Its been open to the weather up here in Alberta for a long time...
50_Fastback
50_Fastback
Loc: California Central Coast
Reg: 09-08-14
01-06-19 05:03 PM - Post#2756731
    In response to 40grit
40 Grit,
Do you have a pic of the lower shock mount on your car?
Ron Starkey
Life's full of risks..........take one!
'50 Fleetline 350/350
40grit
40grit
Reg: 07-08-13
01-06-19 06:27 PM - Post#2756736
    In response to 50_Fastback
Surprizingly, I did not find one. I did find this one if you can zoom in on it.
The lower shock mount and U -bolt plates are factory origional. I did measure my travel and ordered a shock that is an inch shorter than factory though I have been told the stock shocks will work. That I can not vouch for.
Execution time: 0.12 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:52 PM
