Username Post: 2003 4.3 rear main seal        (Topic#354678)
fitter
Loc: saint louis missouri
Reg: 09-27-03
01-02-19 09:24 AM - Post#2756331
Does the pan have to dropped to replace seal in a astro van
Senior Chevytalk Moderator
01-02-19 11:14 AM - Post#2756347
    In response to fitter
No, but the trans needs to be pulled back. Next the flex plate comes off. It's a one piece seal. Are you sure it's leaking? Check the rear valve cover area. Next, the mating surface between the lower intake and block edge. Next, the oil pressure sensor too. If any of those leak, it will look like a rear main seal leak.
fitter
Reg: 09-27-03
01-02-19 12:50 PM - Post#2756355
Execution time: 0.083 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:52 PM
