Username Post: Oil pan capacity        (Topic#354673)
tvdmusic
Reg: 01-01-19
01-01-19 08:07 PM - Post#2756304
I am new here. I just built my first big block. I have a 396, bored .040 over, balanced, dome pistons and a lot of good stuff in it. Doing some reading I have seen it go back and forth about using a high volume oil pump with a stock pan. My pan is a little over stock, 5 quarts, is that enough. I also have a windage tray installed. Thanks!
Edited by Tony on 01-02-19 09:38 AM. Reason for edit: Moving to Performance Forum
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-02-19 10:26 AM - Post#2756341
    In response to tvdmusic
having a larger capacity oil pan is always an advantage ,
but control of the oil is vastly more important, than capacity,
theres no real advantage in use of a high volume oil pump in a nearly stock engine,
If you post the info on your car make/model
I may know where you can find a baffled high capacity oil pan at a reasonable cost.
Edited by grumpyvette on 01-02-19 11:31 AM. Reason for edit: No reason given.
Execution time: 0.115 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:02 AM
