Username Post: 63 c10 Rochester throttle return spring location        (Topic#354633)
imp67ss
Reg: 01-13-13
12-30-18 06:18 PM - Post#2756038
I have a 1963 c10. Single barrel Rochester. The engine is a 292 as far as I can tell. It has no return spring so the throttle rod has a lot of play. Does anyone have a few pictures of a stock location of the return spring? I can see one hole on the bracket where the rod connects. As for the other side towards the carb no connection. I can rig something up to work, but would like to get it as close to correct as possible. Thanks.
Edited by imp67ss on 12-31-18 07:21 AM. Reason for edit: No reason given.
Execution time: 0.137 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:39 AM
