Username Post: Short/long water pump 396 67 SS        (Topic#354616)
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
12-29-18 08:20 AM - Post#2755904
I have a 67 SS that after many years am finally starting to put back together after getting it back from the body shop. Since I didn't take it apart it is somewhat of a challenge even though I have all the manuals & catalogs. My question is how do I tell the difference between a long & a short water pump & what should/can I have on the 67 with 396. The new pump I bought matches the length of the one that was on the engine but the pulley grooves don't line up. I don't think the pump that came with the car was ever used tho & the pulley may have been just thrown in. The car will have power steering. This is probably the first of many questions to come. Thanks for any help & have a good day
57 210 4dr, 57 2dr ht project, 67 Chevelle SS project, 40 Chev coup project
bel-air 62
Reg: 01-16-05
12-30-18 03:21 AM - Post#2755972
    In response to J REID
67 Chevelles all engines use a short water pump. Do your pumps have a casting number?
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
12-30-18 01:05 PM - Post#2756020
    In response to bel-air 62
The pump that came with the engine is A2?8 with some kind of marks before & after. Couldn't read the 3rd. There was also a 8868284. I am assuming this was the right one for the car but??
The one I bought was a new aftermarket. The length of the new one matches the old one but the pulley grooves don't line up is what had me wondering as there are other things wrong or missing with parts that came with the car. Thanks for the reply
bel-air 62
Reg: 01-16-05
01-02-19 04:47 PM - Post#2756388
The original casting for 65 to 68 is 3856284 and will measure 6 inches from the block to the face where the pulley sits. A long pump measures 7.5 inches to the same points.
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
01-29-19 12:43 PM - Post#2758492
Are they off just a little bit? You can take the cover off of the back of the water pump the move the shaft one direction or another to line up the pulleys. You probably need to use a press.
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
02-23-19 02:50 PM - Post#2760573
I have the short pump as it measures 6". I didn't know if the pulley was right for my application so I ordered one from Ground Up thinking that would fix it. It lined up worse & when I spaced it out to where it lined up it interfered with the crank pulley by a quarter inch or so. Sent it back & am cooling off while I try to get other things done. Sorry for the late reply & thanks for your replies. 3 steps forward & 1 step back most days.
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
02-23-19 08:41 PM - Post#2760600
I forgot to add that I am trying to find a Chevelle with 396 or picture that shows the pump & drive pulleys. Also the same picture or Chevelle with air conditioning which is the pulley that I think that I have - maybe???
bel-air 62
Reg: 01-16-05
02-24-19 06:22 PM - Post#2760715
I have a 67 SS Chevelle but don't think pictures are going to do you any good. Can you give us the part numbers on the pulleys you have?
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
02-25-19 01:25 PM - Post#2760791
351?8JAA It's a dual pulley, the only one that I know I have. The ? looks kind of like a small 0. Didn't realize there was a # on the pulley. I did notice yesterday that I hadn't tightened up the bottom pulley & that looks like it will help. Cleaned up the bolts & painted, will asm today. Where do you find part numbers & do a lot of the parts have them on the part? I need all the pictures I can get as I have never worked on a 67 Chevelle before & I didn't take most of it apart & what I did take apart was 12-15 years ago. Thanks for your help.
Edited by J REID on 02-25-19 01:30 PM. Reason for edit: No reason given.
J REID
J REID
Loc: SW Minnesota
Reg: 04-09-04
02-25-19 03:42 PM - Post#2760808
I put the bolts in & torqued & it helped but by the way I checked it is still about a tenth of an inch too deep. Might work but I want it to be right. Will check to see how thick the spacers are that they sell. If not right will have to make one. I am sure this is the first of many questions I will have. Thanks again
Execution time: 0.115 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:14 PM
