Username Post: ‘57 Control Arms        (Topic#354597)
OL55
OL55
Reg: 01-01-08
12-28-18 02:50 AM - Post#2755762
Are the ‘57 control arms the same as ‘55 and ‘56? Can ‘5 and ‘6 arms be used on a ‘7? I have some extra arms I was going to rebuild before installing.
12-28-18 11:04 AM - Post#2755798
    In response to OL55
Yes, all 3 years are the same.
OL55
OL55
Reg: 01-01-08
12-30-18 02:34 PM - Post#2756023
    In response to acardon
Thank you. I know they went to 14” wheels so wanted to check before I redo the suspension.
56chevytimes2
56chevytimes2
Loc: Dale City , VA
Reg: 04-14-04
12-31-18 06:49 PM - Post#2756185
    In response to OL55
hello Larry
Kurt from the old Capitial Classics question for you . Do you by chance have a 55 -57 manual bell housing for the V8 that you would be will to sell I am working on putting a 4 speed in mine.
Kurt
56 4dr 210 wagon Grocery getter
56 4dr 210 sedan Betsy's Page
The Rest of the Garage
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
12-31-18 08:58 PM - Post#2756194
1957 upper control arms are different from 1955-1956. The are cut different to make room for the 14 inch wheel and FATTER TIRES.
The 1955-56 arms were discontinued in parts are 1957s were sold for replacement
If 1955-56 arms are used with the 1957 wheels and tires the tires will rub.
01-01-19 10:00 AM - Post#2756234
    In response to Gene_Schneider
I understood the ball joint was changed, not the arm. Group 6.164 in parts book.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
01-01-19 04:23 PM - Post#2756282
Yes, the ball joints were improved for 1957.
Under front suspension.1957 passenger cars "Upper control arm is the same as the 1955 and 1956 arm EXCEPT that the outer horinzontal flange is trimmed to allow full wheel turn with 14 inch tires. The 1957 control arm can be used for 1955 and 1956 )replacement) service."
The 1955-1956 are was discontinued and 1957 arm replaced it .
1955-56 arms were part numbers 3727729-730, replaced 11-1-57 with 1957 part numbers 3733809 and 810.
Edited by Gene_Schneider on 01-01-19 04:42 PM. Reason for edit: No reason given.
Execution time: 0.063 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:25 AM
