Username Post: Motor Mounts        (Topic#354596)
truck490
Reg: 04-14-14
12-27-18 10:26 PM - Post#2755751
57 Chevy 383 eng Patriot headers 700r4 griffin radiator w/50/50 mix 3000cfm elec fan side motor mount brackets
Using energy suspension mounts and they’re getting hot enough to ‘melt’ or loose their strength
Local club members suggestion have been timing and or running too lean
Energy Suspension suggested installing a heat shield which I have a design for one BUT this really doesn’t solve the problem of engine getting hot. Temp gauge is not showing excessive temp. This latest set made it to Bowling Green Kentucky from Dallas only
Looking for other ideas this problem is on other sites also
Thank you
Larry
Nick P
Nick P
Loc: De Queen, Arkansas
Reg: 10-15-03
12-28-18 07:52 AM - Post#2755776
    In response to truck490
What does ES say about the applied heat? What is the temp being applied?
truck490
Reg: 04-14-14
12-28-18 08:33 AM - Post#2755781
    In response to Nick P
ES response:
Not sure what temp is although I am not overheating and both temp gauges 200 max
Hi Larry,
Our engineering team are going to reject the warranty on these for 2 reasons.
1. These mounts are outside our 2 year manufacturer’s warranty on our products.
2. These were too close in proximity to the exhaust. Our engineering team suggest moving the exhaust at least 2 inches from the mounts and or an aggressive heat shield like the OE’s make. The threshold for our products to be melting is 275-300degrees. This would not be a manufacturers defect cause of failure.
I wish we could help further with this but it is at your discretion to correct or move to another style mount.
Let me know what address you would like us to mail you these mounts back Larry.
Best Regards,
Sean
Sean Crary
Performance & Powersports Sales Manager
Energy Suspension
949-361-3935 x 254
www.energysuspension.com
2018 SEMA Booth #23267
2018 AIM Expo Booth #1634
2018 PRI Booth #4708
FB_icons sigIG icon sigYT icon sigTW icon sig
Confidentiality Notice: The information contained in this electronic mail message is intended for the use of the individual or entity named herein and contains information that may be privileged, proprietary, confidential and exempt from disclosure. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution or copying of this message or its contents is strictly prohibited. If you have received this message in error, please contact the sender immediately.
Nick P
Nick P
Reg: 10-15-03
12-28-18 08:39 PM - Post#2755869
So, how close is your exhaust? What they say seems plausible. And certainly, they should know. Review how OEM heat shields are built and maybe you can deploy this suggestion from them. Are you running headers? If so, this may be a costly solution.
12-30-18 08:06 AM - Post#2755979
In another forum, you said you had run the same setup for a long time until recently the motor mounts have failed twice, apparently from heat. I suspect the exhaust heat is the only thing that could have changed.
TR56210
Reg: 10-28-18
12-30-18 12:09 PM - Post#2756008
    In response to acardon
And your melting both motor mounts??? But your starter is ok? And temp is normal?
Access one of those heat measurement guns to determine how hot is hot.
Wrap the headers. Wrap starter.
Consider replacing temp sensor and temp gauge.
We share the same drive train, 383, 700r4, headers, but old school cooling fan. Not road ready yet. Replacing side motor mounts is really rare. So, interested in what you find and how you fix this.
HYPR
HYPR
Loc: Shaking and Burning!
Reg: 07-19-01
01-29-19 06:40 PM - Post#2758527
I have never heard of the problem you are having. Perhaps you could post some photos from above and below to show how close they are. From the on set I would recommend changing the headers but until we see how close they are that is at best a wild shot in the dark.
Bob
Execution time: 0.104 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:54 AM
