Username Post: Generator light stays on        (Topic#354594)
55nomad
55nomad
Loc: Spring, Tx
Reg: 12-27-02
12-27-18 03:39 PM - Post#2755738
Greetings,
I've installed a "rebuilt" generator but my GEN light stays on regardless of engine speed. I'm hoping this is something simple as a rebuilt generator isn't inexpensive and I'm past the warrantee return date; life gets in the way of the hobby sometimes. Can you give me some tips on how to test the generator.
Also, can someone explain polarizing the generator and when it's done? I didn't do this when I installed the generator but I think I did it today..... short wire & spark between Bat & Arm terminals on the regulator. I don't like sparking electrical stuff! No change on the GEN light.
Many thanks,
Tom
Tom
Beltfed
Reg: 10-04-18
12-30-18 05:03 PM - Post#2756036
    In response to 55nomad
1. The cutout relay is not closing. Take the cover off your regulator and see if that is/is not happing. 2. You have dirty contacts that need cleaning. Use something like a business card. No files or sandpaper. 3. You got a bad connection somewhere in your charging circuit.
Tell us what your voltmeter reads.
55nomad
55nomad
Loc: Spring, Tx
Reg: 12-27-02
01-07-19 06:31 PM - Post#2756815
    In response to Beltfed
Thanks. I'll give this a try
Tom
Execution time: 0.098 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:58 PM
