Username Post: Cowl Tag Missing        (Topic#354592)
Mja1975
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
12-27-18 01:47 PM - Post#2755730
Hello,
The cowl tag that belongs on the fire wall of my '67 is missing all the other vin plates are in proper location. From the vin on the drivers door jamb I can decode that it was assembled in Janesville, WI and its V8 but I dont know original size small block or exterior/ interior colors. Is there a way to locate this information?
Attachment: Screenshot_20180726-204052_Samsung_Internet.jpg (992.46 KB) 16 View(s)
1967
307
400 Turbo
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
12-31-18 09:50 AM - Post#2756097
    In response to Mja1975
You cannot tell the engine size from the VIN or cowl tag. An unfortunately, the exterior color and interior color of the car are located on the cowl tag.
Try this:
Engine --> I see the holes for the engine emblems are filled in on the front fenders. Look on the INSIDE if the fenders to see if you can see evidence of holes for the emblems. Count the holes and measure the distance between them and we can probably figure out the engine, are at least narrow it down.
Paint --> look for evidence of the original color in the door jams, under weatherstripping, around hood and trunk.
Interior --> Look for evidence of the color on the dash, glove box, dash pad.
Good luck!
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
Edited by BigDogSS on 12-31-18 09:51 AM. Reason for edit: No reason given.
Mja1975
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
12-31-18 10:45 AM - Post#2756112
    In response to BigDogSS
Thank you for your reply. I will follow up and report what I find.
1967
307
400 Turbo
59fins
59fins
Loc: Surprise Az USA
Reg: 04-07-00
01-01-19 02:35 AM - Post#2756210
is the rear end a 10 bolt with 1 upper arm? if original rear end, would be a 283, or 327 w/ powerglide (most likely) if it has 2 rear UPPER control arms, could be a 327 w/turbo 400 trans or manual, it could be about anything, being a straight Impala, it would not have 4D for Z24 or SS427, as Janesville would of had "4D" on an SS w/ that package.
Thought I seen a Z03, (a 427 SS with 427 w/o Z24 package) a while back in a story where "L36"
was on the cowl tag. but must be mistaken.
Of all the things I miss, I miss my mind the most
Bill H.
67 Impala SS
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
01-02-19 09:42 AM - Post#2756334
    In response to 59fins
  • 59fins Said:
is the rear end a 10 bolt with 1 upper arm? if original rear end, would be a 283, or 327 w/ powerglide (most likely) if it has 2 rear UPPER control arms, could be a 327 w/turbo 400 trans or manual, it could be about anything, being a straight Impala, ....
Good info here to narrow it down.
  • 59fins Said:
Thought I seen a Z03, (a 427 SS with 427 w/o Z24 package) a while back in a story where "L36" was on the cowl tag. but must be mistaken. ....
Bill, that was for the 1968 model year, when the "SS" package became an option on the Impala. 1967 was the last year the Impala SS was a separate model in the line Chevrolet line up.
Edited by BigDogSS on 01-02-19 09:43 AM. Reason for edit: No reason given.
Mja1975
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
01-02-19 10:05 AM - Post#2756338
Hello, it is a 10 bolt rear end with 1 trailing arm. I believe yes it was a 2 speed. It currently has a th400 but that was added a while back from a pickup. I havent had a chance to check the stamp on the rear axle I will try this evening. The car has been painted a few different times the first repaint was blue. So I really cant find any evidence of original color. I was hoping there was a heritage website that I could get info from or re order build sheet from vin. But doesnt appear so.
Thanks for you comments
1967
307
400 Turbo
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
01-02-19 10:25 AM - Post#2756340
You're welcome. Yes, definitely a 283 or 327 car. I wish there was a heritage website, but at this point there is not. The closest we have is the site CT member WarrenL has put together --> http://impalas.org/numbers/
PM your VIN to Warren and there a very small chance he could have info on your car.
What is the assembly plant for your car? --> 7th digit in the VIN. This will be a letter code.
Edited by BigDogSS on 01-02-19 10:30 AM. Reason for edit: No reason given.
59fins
59fins
Reg: 04-07-00
01-03-19 09:03 PM - Post#2756521
yep, I believe you are correct
Bill H.
67 Impala SS
65acadian
65acadian
Loc: Manitoba, Canada
Reg: 08-15-04
01-03-19 10:04 PM - Post#2756527
Check the fuel line diameter from the tank to the engine. 283 or 6 cylinder would be 5/16" OD, 3/8" would be 327 or larger. That may narrow it down.
Mja1975
Mja1975
Loc: San Jose , Ca
Reg: 06-28-12
01-03-19 11:15 PM - Post#2756530
    In response to 65acadian
Good idea! Thank you will do tomorrow
Moe
1967
307
400 Turbo
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-04-19 07:23 PM - Post#2756590
There is a Canadian fella that sells reproduction cowl and VIN tags; they are BLANK tags however. You can pretty much assemble your car the way you want, and they are't CHEAP! Now, don't chastise ME; the information is out there on the net, Craig's List, and on E-Bay. There you go! I am Butch/56sedandelivery.
Execution time: 0.072 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:05 AM
