Username Post: 95 impala speedometer display        (Topic#354528)
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
12-24-18 09:48 AM - Post#2755473
the speedometer/odometer/turn signal/high beam display on my 95 impala does not work intermittently. when it works, I can dim it just like it should. when it does not work,the gauge lights are still on and dimmeable.
any ideas would be appreciated.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
cloudmaster
cloudmaster
Loc: Arrowsmith, IL
Reg: 01-30-02
08-07-19 09:33 AM - Post#2772618
    In response to 62chevy427
This is an old post, but...
The contacts between the "LCD"part and the rest of the cluster get dirty/corroded. A lot of times, if you pull the cluster out, you can undo the screws which hold that part on, you can see that there are spring contacts on the back of it, and little solder lumps on the display circuit board. You can rub on them with an eraser, a small nylon wheel on a Dremel (not a wire wheel; that'll wear away the solder lumps pretty fast), or electrical contact cleaner. There are all sorts of DIY cleanup methods which are possible.
In any event, a lot of times you can clean those contacts up on both sides and fix that flickering issue. If not, look up how to swap an "analog" F-body gauge cluster in. It just plugs in, but you have to trim a little plastic. Or get the analog cluster from a '96 - same plug-in swap, as I recall.
'71 Malibu: 350/200-4R/3.73 Eaton posi
'75 Elky: 350HO/TH350/3.42 peg leg
'85 C20: EFI454/TH400/3.73 locker
'95 Caprice Wagon: LT1/4L60E/3.42 posi
'04 Grand Marquis: 2V4.6/3" pipes/SCT flash
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
10-09-20 04:21 PM - Post#2805176
    In response to cloudmaster
thanks. i do not get on here often enough. i did as you said, and it worked until this week. now everything is dark. i think the power supplu (right behind the cluster) went bad. going to send it out to be rebuild.
95 impala (new)
15 chevy equinox
Execution time: 0.115 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:46 AM
