Username Post: Choke tube replacement        (Topic#354518)
chnaus
Loc: Upstate:The Real New York
Reg: 04-18-03
12-23-18 07:45 AM - Post#2755349
The fixed choke tube in my exhaust manifold is broken in two.
Has anyone ever replaced this tube
Is there a repro part available
CH
12-23-18 09:34 AM - Post#2755366
    In response to chnaus
You may have to drill the old one out, but try not to enlarge the hole. The new one has to fit tight in the manifold to prevent exhaust leaks. Link to manifold tube.
chevyman57B.C.
Reg: 08-29-12
12-23-18 09:41 AM - Post#2755367
If interested I have a stainless tube NEW for the heat tube. The old ones is hard to get out.
Larry gm1957@embarqmail.com
YOUNG57
Loc: Tennessee
Reg: 12-06-10
12-23-18 11:52 PM - Post#2755442
    In response to acardon
Get the replacement tube shown above before you start so you can see what you are dealing with.
Your original heat tube probably rusted in two. The remains can be driven out with the appropriate size drift punches or drilled out with the appropriate size drills. The top end is larger than the bottom end.
The top end is a larger diameter to accept the tube that goes to the carb choke housing. The top has a flared edge to keep it in place and from falling through. If the tube isn’t a tight fit you may want to flare the bottom end as well to seal leaks and hold it in.
Execution time: 0.096 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:27 PM
