Username Post: 95 K1500 w\305 TBI EGR problem        (Topic#354511)
VChief101
Reg: 12-22-18
12-22-18 02:35 PM - Post#2755308
Bad EGR valve recently replaced. Truck now bucks and backfires after it warms up. In diagnostic mode the EGR valve opens when vacuum is placed on line from TBI to egr solenoid. EGR does not open when vacuum placed on same line after engine warm. So I replaced coolant temperature sensor with Duralast sensor, still won't open and runs worse! Any ideas?
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
12-24-18 09:36 PM - Post#2755528
    In response to VChief101
Welcome to ChevyTalk.
I dont care for Duralast first off. MAy be just me.
Like to stick with oem or standard if oe is not available.
Is the vacuum getting supplied to the solenoid, and from the solenoid to the valve?
Is it the correct valve? There is 2 types, positive, and negative. Must match.
The fact you are saying it is running worse makes me wonder if it has the wrong valve installed.
Old School GM fan FOREVER
Edited by rockfangd on 12-24-18 09:39 PM. Reason for edit: No reason given.
Execution time: 0.154 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:04 PM
