Username Post: radiator ?s        (Topic#354451)
rod
Loc: kingman,az
Reg: 04-29-00
12-18-18 04:34 PM - Post#2754961
my 56 Nomad is a strictly drag race car. several ago, I had a new core put on my original tanks. I race at Vegas, where it is hot most of the time. the new core never cooled down, even with my stock class 265 [currently a 11-1 327]. so it is time for something different. my choice,is an aluuuuminium stock type replacement or a cross flow. I have the battery in front of the radiator on the pass side. as I do not want the battery inside the car. I also want the radiator on the front of the cross bar, so I can use a puller fan [pusher now].
so guys....which cools better, a vertical or cross flow. tube size and fin count and core being the same square inch area.
with a cross flow, I can go wider, as a total remodel is going to be required in either style.
what do I look for in tube size, number of tubes and fin count?
also I see that Jeg's has a double pass cross flow. thoughts on that style.
thanks in advance.
Rod in AZ
Execution time: 0.086 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:19 PM
