Username Post: 1957 Generator gets hot        (Topic#354430)
garyi
Loc: Pasco, WA
Reg: 12-12-18
12-17-18 09:20 AM - Post#2754803
The generator on my 1957 Chevy gets really hot after I drive a bit. Is it the generator, regulator? It is on a small block 327 engine.
Edited by garyi on 12-17-18 09:26 AM. Reason for edit: No reason given.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
12-17-18 01:47 PM - Post#2754842
    In response to garyi
The generator is air cooled. Fan on front pulley pulls in cool air from rear. Should get warm. If it gets really hot may be a problem with the volt/amp setting of the voltage regulator.
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
12-19-18 02:36 PM - Post#2755038
It will get hot if it's overcharging. If the voltage regulator is stuck open the generator will overcharge to the point of boiling the acid in the battery.
Jalapeno
apix17
Loc: San Francisco Area
Reg: 12-22-07
12-21-18 10:08 PM - Post#2755251
You might also consider loosening the belt and rotating the generator pulley by hand to see if it turns freely. I am thinking about a possible bearing problem. Do this with the ignition off of course. Good luck let us know what you find.
12-22-18 05:21 PM - Post#2755318
    In response to apix17
Is the generator functioning properly? I.e., charging at the correct voltage?
Did you polarize the generator after having it disconnected? If not polarized correctly it will try to act as a motor instead of a generator, which makes heat (and it won't be charging).
How hot is "hot"? It should generate some heat when charging, it's not all that efficient.
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
01-16-19 08:46 PM - Post#2757581
    In response to Rick_L
I had a generator that got so hot it quit working. Turns out the rear bushing was so worn out that the armature was rubbing on the field and the friction overheated the armature windings and shorted out. I just changed the rear mounting and armature and all is happy.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
Execution time: 0.363 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:41 PM
