Username Post: Engine measurement in frame        (Topic#354404)
Shortcar55
Gold Supporting Member
Shortcar55
Reg: 12-16-18
12-16-18 05:26 AM - Post#2754644
I am building a gasser body off. I’m using a 502 big block. I would like to set the motor lower than stock and 1.5” forward.
I still have the clutch ball on frame and I’m not sure but I think the clutch ball on motor was in the bellhousing and not on motor above the oil filter.
Also does anyone have the measurement from the ground to bottom of the frame on a stock 55
Execution time: 0.089 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:07 PM
