Username Post: Center console and glove box        (Topic#354387)
TR56210
Reg: 10-28-18
12-14-18 04:36 PM - Post#2754529
Well, the new wiring harness install is progressing nicely, with power windows, radio and ac wiring the biggest non interior related items. I want to finish this before working on mounting and powering the bucket seats.
Which brings me to the forum asking, what center console did you repurpose, build or buy?
Second question popped up as I write.
With the addition of the AC, I don’t think I have room for a tradional glove box. Has anyone modified the glove box to install gages, tach, water, oil ?
Originally, I wanted to mount gages in the center console but the higher dash location .......
asbicca
asbicca
Loc: Southern California
Reg: 07-18-03
12-14-18 06:13 PM - Post#2754537
    In response to TR56210
www.classictruckconsoles.com their Cruiser Model heavily modified
[image][/image]
Made my own glove box out of 1/8" ABS Plastic sheet
http://s2.photobucket.com/albums/y40/asbicca/55 %20...
12-14-18 06:59 PM - Post#2754539
Made my own console with glove box in it and used a Cadallic shifter.
Gauges weren't installed yet in these pictures.
TR56210
Reg: 10-28-18
12-14-18 11:19 PM - Post#2754554
    In response to acardon
Thanks for responding. I will visit the website.
Arcadian, I do have extra black leather hide....so can you walk me thru basics, materials used etc. I really like the natural curve you made.
I assume once seats are mounted I take critical measurements, length width height etc. Then, make cardboard mock up to refine.
What material did you use for the structure, thin sheet metal, wood, fiberglass? I assume you added 1/4 or 1/2 padding under your red leather.
You got me excited to finish the wire harness!!
12-15-18 07:33 AM - Post#2754568
I used wood and fiberglass and body filler. The upholstery is glued directly on the console.
TR56210
Reg: 10-28-18
12-15-18 03:40 PM - Post#2754607
Thanks again. The classic truck console web had some great measurements as a starting point. I really like the curve you made and will incorporate in mine. Uncle has deep fiberglass background so likely will go that way first, and include him in project.
In the upper part of the console where the gages will reside, I want to bias or point the gages toward the driver to aid visibility. In your opinion, is gage visibility an issue with a flat console, or am I over thinking this? And who would ever think that a phone charger port would become a must have feature in a tri five....
12-16-18 10:12 AM - Post#2754674
I don't think it's necessary to tilt the gauges. Your far enough away from the gauges to see all the gauge. Although it wouldn't be hard to tilt them. As you see, I recessed the gauges a little. You could drill the holes at an angle and counter sink them at the same angle.
TR56210
Reg: 10-28-18
12-16-18 05:39 PM - Post#2754728
Over football this afternoon, my uncle convinced me that building a reverse mold for fiberglass console was much tougher than going with wood as you did. So, mock up in cardboard then get the saws and sanders out.
KaelFarmer
KaelFarmer
Loc: Eau Claire, WI
12-16-18 06:58 PM - Post#2754733
In my opinion, I would agree with Don that there is no need to angle the gauges.
My reason for stating this is that I previously owned a 1971 Open GT and I now a 1977 Corvette. The Opel GT had the gauges in the center area above the radio and they were angled toward the driver. The Corvette also has gauges mounted above the radio in the center of the dash area although they are mounted straight.
In all honesty, those gauges are about equal between both cars. The only specific thing I like better about one of the dash layouts better than the other is that I like the speedometer location in the Opel. In the Open the tachometer is on the left and the speedometer is on the right. In the Corvette, they are opposite. I like the speedometer on the right since I scan it and my other gauges more often as a group than I do the tachometer.
Also, keep in mind that almost anytime you look at the gauges,you are looking to see if they indicate within a specific range. Even when doing inspections for commercial vehicles, we want each gauge to within a target range. I have never been looking for a specific number or else I would switch everything to digital. Also, I don't really think that any of these gauges (including digital) can be considered a precision instrument so the viewing angle is not so critical
Kael
Execution time: 0.075 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:28 AM
