Username Post: Axle bearing numbers?        (Topic#354385)
Beltfed
Reg: 10-04-18
12-14-18 01:40 PM - Post#2754512
Am repacking the axle bearings and noticed one hub doesn’t fit up against the backing plate far enough. Checked seal and such. I’m starting to believe the inner bearing is two wide. Can’t find any data on the correct bearing number for the front spindle. Can you help with the correct numbers? All original 1957 Bel Air and want to keep it that way. Thanks.
DECEASED
12-14-18 02:30 PM - Post#2754519
    In response to Beltfed
The inner is 909040 and the outer is 909001.
radioheaterwsw tires
Reg: 08-24-14
12-16-18 11:26 AM - Post#2754691
909040 and 909001 are GM set part numbers. Generally accepted BCA and others aftermarket numbers are B40 and B01, again, 3 piece set numbers.
57belairman
57belairman
Loc: Missouri City Texas USA
Reg: 03-16-02
12-20-18 06:20 AM - Post#2755109
    In response to radioheaterwsw tires
Life is short, Eat dessert first, I always do!!
Picturetrail
57 2dr ht red
57 Convertible black
57 Nomad larkspur blue
57 3100 Pickup
55 2dr Sedan
56 Suburban
Execution time: 0.099 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:06 PM
