Username Post: Iron heads        (Topic#354376)
Jim.Biron
"13th Year" Platinum Supporting Member
Jim.Biron
Loc: Monterey, TN
Reg: 04-10-08
12-14-18 08:25 AM - Post#2754477
Looking for a recommendation.
What are the best double hump heads out there?
I'm looking to build a 'sleeper' of sorts and want the very best heads that I can bolt on that look like the double humps of the early 60's (no bolt holes).
I want to build this 'sleeper' power plan that looks original but has a decent amount of power.
Any recommendations appreciated.
If I must have bolt hols what is the recommendation?
www.HudsonValleyCruise.com
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
12-14-18 08:47 AM - Post#2754480
    In response to Jim.Biron
bolt holes can easily be filled with bondo and a bit of work with some bondo mixed with steel wool carefully sculpted bondo, can even result in bogus camel humps that pass the magnet test, and add some paint and only someone who really knows what they are looking at can tell the difference.
paint and some cosmetics can hide a great deal.
I would not use old original fuelie heads as a start point the flow tech is 70 years out of date,
https://www.hotrod.com/articles/ctrp-0912-ch evrole...
https://www.enginelabs.com/engine-tech/engine/fu el...
heres a better route
https://www.rodauthority.com/tech-stories/engine/d ...
Jim.Biron
Jim.Biron
Loc: Monterey, TN
Reg: 04-10-08
12-14-18 09:20 AM - Post#2754490
    In response to grumpyvette
I like those trick flows
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
12-14-18 04:34 PM - Post#2754528
If your plans do not included mod to '383' sb, I think you would like the end product. The 'cosmetics' (mostly paint), to make it look like a 327, are not difficult. The low end torque will make for a very nice driving experience.
Just a thought.
Pete
Jim.Biron
Jim.Biron
Loc: Monterey, TN
Reg: 04-10-08
12-17-18 08:52 AM - Post#2754789
    In response to japete92
Just a thought.
Pete
Thanks Pete
Execution time: 0.192 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:45 PM
