Username Post: Front wheel bearing seal direction?        (Topic#354328)
Beltfed
Reg: 10-04-18
12-11-18 03:31 PM - Post#2754177
I’m repacking the front wheel bearings for my first time. The new seal has a lip on the o.d. of about 1/16”. The old seal had no lip. Does that lip go toward the hub, the backing plate, or does it matter? This is the bearing grease seal that goes up against the backing plate. 1957, but I think all tri fives apply.
Thanks.
Beltfed
Reg: 10-04-18
12-12-18 11:07 AM - Post#2754254
    In response to Beltfed
Sorry, that lip is on the i.d. of the seal, not the o.d.
DECEASED
12-12-18 11:13 AM - Post#2754256
That's what I hoped you meant. The lip should face toward the bearing (or away from the backing plate).
Beltfed
Reg: 10-04-18
12-12-18 04:33 PM - Post#2754294
Thanks for the information.
Execution time: 0.053 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:43 AM
