Mcneills48
Reg: 09-07-18
12-09-18 12:42 PM - Post#2753993
Im looking for what other people have used for an ignition switch in place of the floor button. I have a 48 fleetline. I had to get rid of the floor button. I'm looking for an original look on the dash and would like a key start. Is there a 50's or later ignition that would slide right in?
Thanks I
DECEASED
12-09-18 03:29 PM - Post#2754003
In response to Mcneills48
Ok, so specifically you wish to get rid of the foot-operated starter, correct? The easiest fix would be a push-button starter switch such as was used 49-52. If that's not acceptable, you could use a "universal" key-start switch, available from almost any parts store, and of course online. If you want a switch that takes a GM key, you could look at a 53-54, but you would have to cobble the mount, and I'm not sure it would pass for stock.
Mcneills48
Reg: 09-07-18
12-09-18 04:16 PM - Post#2754007
Thanks Ray. Yes I had to get rid of push starter. I'm wanting to have a key start but I don't want to drill the dash out. Will anything work with the existing hole?
DECEASED
12-09-18 06:47 PM - Post#2754015
The universal switch will have a smaller diameter mounting shank than the 53-54. You might want to inspect one at a parts store, measure the shank, and see how it compares with the existing dash hole.
Member #189 Moderator and "21th Year" Platinum Supporting Member
12-09-18 09:25 PM - Post#2754027
Interesting. Why did you have to get rid of the foot operated starter?
29-41, 42-48, 49-54 Moderator
2019 Ford Ranger Lariat Super Crewcab |
Mcneills48
Reg: 09-07-18
12-10-18 12:01 AM - Post#2754033
I put in a 350 turbo tranny so I had to change the tunnel. Things didn't line up anymore.
12-10-18 10:25 AM - Post#2754061
That explains it. Good luck with your switch search.
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
12-10-18 01:45 PM - Post#2754085
Look on the bottom edge of your dash. GM put a few extra holes under there for a variety of accessories. you might be able to use an existing hole with maybe a little enlarging to install a starter button. it would be pretty much out of sight and you could keep the same key switch.
12-10-18 07:53 PM - Post#2754115
In response to lofat46
I did exactly that on a 47 coupe I installed a 56 V8 running gear. This was in 1967 while I was in the Navy. Starter button on the left side on the bottom edge of the dash.
The Flash
Reg: 09-25-19
09-01-22 07:45 AM - Post#2846611
Hi did you ever find a switch that would work?
I'm working on finishing up my swap and done want to use a button if I dont have to
thanks
1947 Chevy Stylemaster Coupe
1959 Chevy Impala Coupe
1966 Olds 98 Convertible
1993.5 Toyota Supra Turbo |
09-01-22 10:36 AM - Post#2846622
In response to The Flash
Original poster has not posted for 2 years.
The Flash
Reg: 09-25-19
09-01-22 11:13 AM - Post#2846623
well hopefully some one else chimes in
