Username Post: 62 radio installation        (Topic#354280)
fander
fander
Loc: Hot Springs South Dakota
Reg: 04-28-12
12-08-18 05:21 PM - Post#2753913
Can't figure out how to get my factory radio installed. Is it supposed to go above the cross bracing in back and then forward? Not enough room to get the knobs in the holes. Thanks
58Yeoman
Loc: Burlington, Ontario
Reg: 12-22-15
12-08-18 06:58 PM - Post#2753923
    In response to fander
I just installed a radio in my '61 which should be the same as your '62. I pulled the glove box liner out and also took the glove box door off. Had no problems positioning radio and lining up knobs. John
1958 Chevrolet wagon (Yeoman)
1958 Belair (parts car)
1961 Impala convertible
1964 Impala Sport Sedan (parts car)
fander
fander
Reg: 04-28-12
12-08-18 08:03 PM - Post#2753937
    In response to 58Yeoman
Thanks for the reply. I took the glove box out but didn't take off the door. There is a bar that goes across the area behind the radio. If I try to get the knobs in I can't lift the rear of the radio enough to get the radio in. I don't know if the radio is supposed to go above the bar and then slide forward. The problem with that is to get the radio above the bar I would have to remove the speaker which I don't think I could get back in after the radio is in. I also have vintage air ductwork which runs above and behind the radio. That isn't causing a problem so far but it may if I try to get the radio above the bar and then slide the radio forward.
junky
Loc: Northeast CT
Reg: 06-27-10
12-09-18 06:30 AM - Post#2753965
It is a tight fit, and probably the Vintage Air ductwork was installed with the radio in place. Where you the one that took the radio out, and if so, you should know if the ductwork is going to be a problem.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
12-09-18 07:07 AM - Post#2753967
I have not had to have the speaker out. It needs to be in place before the radio.(I assume you are using the original speaker mount)
The knobs are not on the radio when its installed, just the two shafts on the radio. The knobs go on after the radio shafts are placed in the dash holes.
There is a slotted support as part of the dash - on the drivers side of the radio that uses a stud on the radio to support the radio.
My glove box is not in place, so I can take a picture of my radio from the back side.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Web http://paulstensland.com/
fander
fander
Reg: 04-28-12
12-09-18 08:09 PM - Post#2754025
    In response to junky
I took the radio out but it was over 30 years ago.
That bar in the middle is what is causing me problems. I can't get the radio in by bringing it up from the bottom as the back of the radio hits the bar before the radio is lined up. I am wondering if the radio goes in above that bar and then slides forward.
I had the radio converted to AM, FM, and Aux by S&M Electro Tech in Blaine MN but there is no change in the external dimensions of the radio.
By the way I love the vintage air and I hope I don't have to reroute those hoses to get the radio in.
Attachment: radio.jpg (240.56 KB) 12 View(s)
Attachment: radio1.jpg (130.54 KB) 12 View(s)
junky
Loc: Northeast CT
Reg: 06-27-10
12-09-18 08:31 PM - Post#2754029
It looks tight, but doable. What specifically, are you hitting when you attempt replace the radio. From the picture, it appears that the distribution box might be in the way, but I just can't tell for certain.
I have been thinking of doing the same thing with my radio. Let us know how well it works when you get it back in.
fander
fander
Reg: 04-28-12
01-09-19 08:25 PM - Post#2757004
I got my radio in. The fellows who installed the vintage air ran the duct work through a hole near the front of the dash instead of the hole near the rear of the dash. This didn't leave room to install the radio. I am happy with the radio. I have am/fm with aux input. I also ordered new speakers for the front and back from S&M Electro. A minor thing with the rebuilt radio is they use the original tuning knob which must still be controlled by a string as there is some play in the selector when changing stations. Radio looks original except there is a light showing am/fm/aux. The light is to the right side of the tuning dial by the numeral six and you can see the light in the picture.
Attachment: radio.jpg (509.04 KB) 4 View(s)
omarine
Loc: San Diego
Reg: 06-29-15
01-10-19 04:55 AM - Post#2757015
i think this looks great, and would like to do the same with my 61 radio. I also have vintage air and now know what to be aware of.
I currently have one of those retrosound vintage looking radios with Bluetooth and all the doo-dads.
would be nice to also replace those oval speakers in the dash with new ones.
thanks for the update on this.
cheers
Oscar
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-11-19 06:59 PM - Post#2757165
    In response to omarine
Glad you got it in. Looks awesome. It should sound great with the new speakers. Those oldies will sound much cleaner now I bet!
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Execution time: 0.077 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:28 AM
