Username Post: How fasten trim on the front fenders imp-70?        (Topic#354266)
Tobias_Sweden
Reg: 12-07-18
12-08-18 07:45 AM - Post#2753848
Hi all!
I have an impala 1970 that i just got some new paint on :). Now i'm about to install the body moldings/trim. But on the front fenders... how is it supposed to reach to fasten the nuts for the trim clips? It can't be supposed that you should take out the inner fenders?
Is it possible to reach enough to mount all of the nuts if you take away the bent sheetmetal part far down in the rearest part of the wheel-well?
I took of the fenders and repaired them prior to the paintjob, and am not keen at all to take newly painted fenders off again.
Hope my English is readable... not my first language.
69 RAG
69 RAG
Loc: Newfoundland
Reg: 02-19-16
01-17-19 07:33 AM - Post#2757593
    In response to Tobias_Sweden
Hey Tobias. Nice intro. When I replaced fender moulding on my 69 after paint I had to remove a lot of inner fender bolts to get access to tighten nuts. Ps. Don’t tighten all till u line up with other trim. Have fun. Jim
Double Aught
Loc: SW America
Reg: 09-28-11
01-17-19 07:06 PM - Post#2757646
You could always use two-sided tape. I used this to attach non-68 Impala SS emblems on my restomod 68 SS.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
01-17-19 07:32 PM - Post#2757650
  • Tobias_Sweden Said:
Hi all!
The clips did nut onto the fender. You could use barrel nuts in the holes and slide the original threaded studs into them. But, using the original speed nuts would be best.
Donny
Edited by aawtech on 01-17-19 07:32 PM. Reason for edit: No reason given.
Execution time: 0.095 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:45 AM
