Username Post: In trunk fuse panel for Tri5        (Topic#354255)
HYPR
HYPR
Loc: Shaking and Burning!
Reg: 07-19-01
12-07-18 11:24 AM - Post#2753739
Does AAW facilitate or can it facilitate with longer wires the relocation of the Fuse panel to the trunk of a Tri5?
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
12-08-18 08:45 PM - Post#2753931
    In response to HYPR
No, not with the Classic update product. You could use the universal Hgwy 22 with the trunk mount kit, but we do not recommend it. That car is too big and the fuse panel ends up being too far away from things. On something like a 32 car, you can get away with it. In addition, the Classic update has all the items to complete your install in a tri5. Those items are not available separately.
Donny
HYPR
HYPR
Reg: 07-19-01
12-09-18 04:49 AM - Post#2753956
    In response to aawtech
Donny
Donny,
That is disappointing. So does the harness allow for placement in any other location OTHER than the stock location?
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
12-10-18 10:19 PM - Post#2754124
    In response to HYPR
  • HYPR Said:
Donny
Donny,
It does not mount in the exact location as the accessory panel does. Go to our website and you can download the instructions so you can see where it mounts. We give you a mounting plate and all the specialized hardware to mount it. What are your concerns?
Donny
HYPR
HYPR
Reg: 07-19-01
12-12-18 12:33 PM - Post#2754258
  • aawtech Said:
  • HYPR Said:
Donny
Donny,
Donny
Thank you Donny, That kit looks pretty self explanatory from looking at the instruction sheets. My only concern is from the initial look the colors do not necessarily correspond to the Tri5 colors so perhaps I can make the Classic update kit work by relocating the fuse panel to the original Tri5 glove box by fabricating a panel to mount it with in the area behind the door. It looks like the distance is about the same with (again without know the lengths) only some very minor concerns regarding wire lengths towards the driver's side). What are your thoughts about doing this?
Thank you,
Bob
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
12-13-18 09:24 PM - Post#2754436
    In response to HYPR
  • HYPR Said:
  • aawtech Said:
  • HYPR Said:
Donny
Donny,
Donny
Thank you,
Bob
No Bob, that will not work. The dash harness is built and all the lengths to the connections and switches are based on the fusebox being mounted on the LH side of the firewall. In addition, the wire colors are later GM style, not 55-7 style. Only OE style stuff will be the original color. What are you building? Details, perhaps I can offer a suggestion or two.
Donny
HYPR
HYPR
Reg: 07-19-01
12-13-18 10:40 PM - Post#2754445
Rewiring a '56 2 door 210 Del Ray. Custom Restomod.
The gauges are VDO Millennium. The ignition is MSD Digital and the Battery is a Yellow Top Optima mounted in the trunk using 1/0 Gauge positive and negative running up the frame rail to the engine compartment. The headlights are HIDs. The ignition switch is yours.
Execution time: 0.183 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:38 PM
