gcrkfrd
"7th Year" Platinum Supporting Member
![gcrkfrd](https://www.chevytalk.org/fusionbb/fbbavatars/av-274251-1639891878.jpg)
Loc: Neosho, MO.
Reg: 04-01-18
05-16-22 08:32 AM - Post#2841274
In response to gcrkfrd
Hey, look at this. Took off, Chinesium Carburetors, and installed Two Bs. Runs much better now. Sorry for Two Pictures.
1952 Styleline Sedan-
Blue 1967 C-20, Survivor.
The only running vehicles I own. |
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
07-10-22 11:12 AM - Post#2844144
An update here----68-72 Chevy Truck blower and fan, do fit where old 6 volt was, but, you have to center the venturi, that is stamped into the firewall, because squirrel cage sits a little deeper than old one, or it will rub. I removed the air duct butterfly fixture from the firewall to eyeball this, before drilling and installing screws in fan motor. Edit---It takes Two People. PS- it does require a 1/4 " rubber spacer, between fan motor plate and stock heater box, to work right
Edited by gcrkfrd on 11-23-22 11:06 AM. Reason for edit: No reason given.
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
09-03-22 07:47 AM - Post#2846711
Built a little garage for Chebby, and keep Her in it. Put Mig welder, Tool Boxes, Jack, Jack stands, Engine Lift, Engine Stand, Future Parts, Small Block, and Parts, Work Benches, Refrigerator, Computer, and Air Conditioner in Garage.
Started out under a Shade Tree, now have to take Her back under a Shade Tree, for room to work on her.
Dean50
"18th Year" Gold Supporting Member
![Dean50](https://www.chevytalk.org/fusionbb/fbbavatars/av-38087-1578975313.jpg)
Loc: Detroit area
Reg: 01-02-07
09-18-22 11:30 AM - Post#2847472
That's great progress lol.
Dean50
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
09-26-22 10:19 AM - Post#2847792
In response to Dean50
Georges Tip-#12---Go to Farm Store, and buy One running Foot of Horse Stall Mat, they have different thicknesses, 1/4", 1/2". Buy the 1/4", it is the handiest thing you can get for your 49-54 Chevy. I used it for Heater Fan Isolation, and Body, and Core Support Mounts. Got a 12" by 72" for $7.65.
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
02-11-23 09:55 AM - Post#2854380
Tried a pair of LED Headlights, for $84, they were shown as plug and play. Did not work, returned them. Ordered another set $114, listed as Plug and Play, did not work. Ordered a Pair for $148, sent them back, and reinstalled Sealed Beam Halogens, they work. Chebby is going out for a ride, this afternoon.
rawaag
![rawaag](https://www.chevytalk.org/fusionbb/fbbavatars/av-63708-1354054186.jpg)
Loc: Williamsburg Virginia
Reg: 06-12-09
02-20-23 08:42 AM - Post#2854777
Thanks for the tip on the LED headlights, I was thinking about changing out my stock to LED. After reading your post I guess I'll go with the Halogen.
Ralph |
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
04-05-23 12:37 PM - Post#2856501
In response to rawaag
Update-Took 4 Bolt 350, to Marty's at Aurora, for Flux, align bore, and to check some scratches in #1 cylinder. Plan to replace 235, and Iron PG, with 350 and short TH350.
tommy49
![tommy49](https://www.chevytalk.org/fusionbb/fbbavatars/av-178859-1709400510.jpg)
Loc: Kaleva, Michigan
Reg: 09-28-12
04-05-23 05:35 PM - Post#2856508
That should be fun!
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
05-02-23 07:23 AM - Post#2857496
In response to tommy49
Picked up Block and Crank- Boiled, Mag checked, Main journals align honed, bored 30, new cam bearings, and new plugs, Crank polished 10 under, bolted to new stand, painted yesterday. More Fun-
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
06-10-23 08:08 AM - Post#2859011
This morning, laying out in Garage- Have 350 Block 30 over, and Crank 10 under, New Pistons, New Rods, New Aluminum Heads, New 350HP-327 Cam and Lifters, New Timing Chain, New Bearings and Rings, New Oil Pump, Shaft and Pickup, All Gaskets, New Head Bolts, New Distributer, New Valve Covers and Timing Cover. New Block Hugger Headers. All Waiting Patiently, for an Old Man, to quit looking at them and Smiling.
tommy49
Reg: 09-28-12
06-12-23 03:32 AM - Post#2859088
Parts! Always a good thing!
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
02-06-24 10:19 AM - Post#2866645
This is how Old Codgers work on their Chevy--Lay out Parts and Pieces, Jack up the Car, find some padding to lay on, get down under the Car, decide you need to take a bathroom Break, fix a Sandwich, go back look at the Car, Pick up Parts and Pieces, roll up the mats, take out Jack stands and Jack. Then set down, and look at the Car.
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
04-01-24 07:05 AM - Post#2868496
Finally got fed up with, Fifteen Minute warmups, backfiring, and driving with the choke pulled out, fouling the plugs. Dug out a stock intake, and exhaust, new intake sleeves, new carb spacer, and am searching all parts for two misplaced manifold washers. Drivability, and mild manners, were something I overlooked, and almost forgot.
tommy49
Reg: 09-28-12
04-01-24 08:42 AM - Post#2868502
The very reasons I went with a 4.8 liter LS.
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
06-05-24 09:18 PM - Post#2870550
Busted down, and bought new windshield and rubber for Chebby. Could not polish glass clean enough, and rubber was cracked every inch. Wanted to be sure, there was no rust under rubber, and garnish. Tommorrow will begin sanding and paint in pinchweld area. Ordered Green glass and rubber from Classic on Monday morning, and FED-Ex brought it on Wednesday afternoon.
tommy49
Reg: 09-28-12
06-07-24 05:29 AM - Post#2870609
My windshield was so unsafe driving into the sun, we couldn’t do late afternoon rides. I bought all new glass, except rear window, but have only changed windshield & sliders.
tommy49
Reg: 09-28-12
06-07-24 06:04 AM - Post#2870610
I do want to mention that I did have a problem getting the stainless trim to fit. The trim ends at the top were too short to fit under the center trim piece, They were ok on the bench, but not in the car. Most likely, the seal was too thick (Clesters seal). I ended up making a small stainless cover. It works, but I need to make a new cover with a better quality of stainless. This one has rusted.
Edited by tommy49 on 06-07-24 06:20 AM. Reason for edit: No reason given.
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
06-11-24 11:05 AM - Post#2870775
Put the windshield and rubber in, rubber upside down. pinch weld groove different between top and bottom. Do it again.
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
06-15-24 08:34 AM - Post#2870884
Thought maybe I messed up rubber that I got from Classic, so ordered new from Chevy Restoration World, reinstalled, yesterday. 1/2" to far forward, center bottom. Got mad this morning, because bottom of windshield was not going back, put two blocks of 2x4, one on edge, another flat, on lower center rubber ratchet strap from door post to door post, tightened up, pulled bottom over pinch weld. Shazam
gcrkfrd
Loc: Neosho, MO.
Reg: 04-01-18
07-16-24 08:02 AM - Post#2871823
Tired of working on Chebby in the Sun. Ordered 12x20 shade from Jungle People. Bolted feet down to 8 Harbor Freight buckets full of concrete. Very nice.
