Username Post: Cool running???        (Topic#354215)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-04-18 05:22 PM - Post#2753381
I drove the 64 to work this morning at 5am when I left the house it was 28* outside. The car had been in the garage and I drive about 20 minutes to work.
The new radiator is doing a great job I guess and maybe even to good. The temp gauge never got over 150* the whole way. It had some heat but not what I'd say was great heat. The dash light didn't go out until about half way to work. That's at 55MPH no stop and go except for 2 stop signs.
It did basicly the same coming home but it was in the 40*'s on the way home.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
IgnitionMan
Reg: 04-15-05
12-04-18 09:19 PM - Post#2753415
    In response to Andy4639
What info on engine, timing and cooling system setup?
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
12-05-18 12:54 AM - Post#2753423
Have you changed anything recently?
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-05-18 03:42 AM - Post#2753430
    In response to kingkreeton
Nothing changed since I installed the radiator about year half ago. I put the shroud back on it this summer.
Motor stock 350 with a stock Chevy HEI big cap, power glide. Nothing fancy.
My buddie came over a few weeks ago and we set the timing 8* BTDC and fixed the electric choke and set the air screws on the carb.
It runs great cranks right up after 2 pumps on the gas pedal.
I wasn't posting to complain other than it being a little cool but I can handle that. I'm sure if I let it sit and warm up good before leaving it would get hotter.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
1963er
1963er
Loc: Joppa, Md.
Reg: 12-20-15
12-05-18 05:15 AM - Post#2753437
Install a 180 degree thermostat...
IgnitionMan
Reg: 04-15-05
12-05-18 06:01 AM - Post#2753444
Which stock GM large HEI, there are over 437 different curve packages for them?
Anything else in the cooling system changed, ran, pulley size, and what thermostat is in it, what coolant to tap water ratio???
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
12-05-18 06:41 AM - Post#2753448
    In response to 1963er
I agree. If the coolant gets to 180 before the thermostat allows full circulation, it likely will stay there (most get a little hotter while running). Aluminum heads? 190.
If you already have 180/190, verify it is not stuck open.
Pete
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
12-05-18 07:09 AM - Post#2753453
Back in the day when I was learning how to tinker on cars, I had the water pump and manifold hoses backwards and my heat wouldn't work very well as a result. But yours sounds like the engine is not getting warm enough. Are you running electric fan/fans with that radiator?
Shane
64 Impala SS:
4 Speed Muncie
Edited by kingkreeton on 12-05-18 07:09 AM. Reason for edit: No reason given.
IgnitionMan
Reg: 04-15-05
12-05-18 09:54 AM - Post#2753471
    In response to IgnitionMan
I am also assuming the temperature gauge has been checked for its being accurate.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-05-18 10:28 AM - Post#2753475
Ya'll, there nothing wrong with the setup. It's fine. It just very efficient at keeping the motor cool when it's cold out side. It has 190* thermostat and it's working fine.
This was the only reason I posted it.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
junky
Loc: Northeast CT
Reg: 06-27-10
12-05-18 02:19 PM - Post#2753500
Cover half the radiator with a piece of cardboard. If it gets too hot, remove cardboard. Easy fix that I used in winters in New Hampshire back in 1962. Cardboard is fast, cheap, easily sourced, and instantly removable without any modifications. If it got wet or deteriorated, dispose of and install another piece.
12-05-18 02:54 PM - Post#2753508
The thermostat is NOT working fine if it doesn't run at 190 degrees. The thermostat holds water in the block until it warms up to 190 degrees. Until then, the radiator has nothing to do with it. If there is no coolant flow, the engine will easily heat the coolant to 190, no matter how cold it is outside. Have you drilled any bypass holes in the thermostat? If not, it is stuck.
P.S. It's not good for an engine to run too cold, especially a EFI engine. The computer may not come out of closed loop to regulate fuel mixture.
Edited by acardon on 12-05-18 02:57 PM. Reason for edit: No reason given.
IgnitionMan
Reg: 04-15-05
12-05-18 03:22 PM - Post#2753516
    In response to acardon
Don is on target, too cold, thermostat.
brokenspoke
Reg: 02-28-08
12-06-18 04:46 AM - Post#2753589
^^^^^^what he said^^^^^
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-06-18 01:55 PM - Post#2753642
    In response to brokenspoke
No it not stuck open. It's just pulling cold air through it to keep the temp down. The shroud is sealed so nothing goes around it.
It was 24* this morning and it was about the same maybe even less. How accurate is the gauge, well this summer when I used the heat gun on the motor it was less than 10* off.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
IgnitionMan
Reg: 04-15-05
12-06-18 09:56 PM - Post#2753695
So, there really isn't a problem, it is supposed to run that cold, so you never need air conditioning.
brokenspoke
Reg: 02-28-08
12-07-18 03:11 AM - Post#2753705
Running under 190 degrees is damaging to your engine.....
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
12-07-18 05:53 AM - Post#2753710
YUP,OIL NOT NEARLY HOT ENUFF TO BURN OFF ANY CONDENSATION THAT DEVELOPS WITH SHORT TRIPS IN COLD WEATHER.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-07-18 05:57 AM - Post#2753712
So when you first crank your engine up and until it gets above 190* it's damaging your engine. I don't know about that but I do know it runs strong and it has good oil pressure.
I would assume if it took me a hr to drive to work it would be up to normal operating temp but for no further than I drive it never see it When it's this cold.
As far as the AC goes the motor running cold are hot has nothing to do with how cold the AC is. The only thing that keeps your vehicle cold is how much air you pull through the condenser for AC and the radiator for the motor, when it's hot outside. My AC runs 38* during the hottest part of the summer all day long sitting are moving. The temp gauge hovers right at 195/200*.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
12-07-18 08:29 AM - Post#2753722
A 190 degree thermostat begins to open (and allow the coolant to flow out of the block) when the coolant reaches 190 degrees. That may take about 5 minutes (or so).
I do not know if your gauge is accurate, but if your engine never gets to 190 (you say it takes 20 minutes to get where you are going), your thermostat is malfunctioning. It is NOT staying closed to 190. It is opening (or not shutting at all) and allowing flow into the radiator at some lower temp (150?).
Just trying to be helpful.
Pete
Edited by japete92 on 12-07-18 08:37 AM. Reason for edit: No reason given.
IgnitionMan
Reg: 04-15-05
12-07-18 08:37 AM - Post#2753723
It is getting a bit out of hand here, folks, a cast iron block/heads engine's optimal operating temp is 180 deg/F. Cast iron block/aluminum heads, 192/195 deg/F. And aluminum block/heads, 200/205 deg/F.
Now, if a cast iron block/head engine is running a 190 deg/F. thermostat, and 150 deg/F. run temperature, there IS a serious problem some place in the cooling system, and it just ain't right.
You guys take it from here, but I would choose to fix it. And, it doesn't matter what the outside temperature is, the cooling system just ain't working correctly.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-07-18 12:57 PM - Post#2753753
Ok.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Stittville Ed
Reg: 01-10-16
12-07-18 04:11 PM - Post#2753765
A plus 1 on that :-)
Execution time: 0.099 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:55 PM
