Username Post: Voltage regulator ?        (Topic#354209)
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
12-04-18 11:13 AM - Post#2753346
Any suggestion as to which way is correct for the “isolator” to face? Thanks in advance, Lamar
Attachment: IMG_5878__2_.JPG (104.98 KB) 7 View(s)
Looks like the metal side of the “isolator” faces engine compartment.
Attachment: IMG_5879.JPG (104.39 KB) 8 View(s)
Attachment: IMG_5880.JPG (100.04 KB) 10 View(s)
12-04-18 11:20 AM - Post#2753347
    In response to PLS
From the picture from the shop manual, the metal part goes up against the grounding strap. You can see the metal through the ground strap holes.
Edited by acardon on 12-04-18 11:22 AM. Reason for edit: No reason given.
PLS
PLS
Reg: 06-07-12
12-04-18 12:05 PM - Post#2753352
    In response to acardon
Thank you, Don, for your reply. I to felt that the picture from the manual shows the correct position but the reason for asking was in the other two pictures that I took you can see that the metal part is on the back. Years ago, I removed the front wiring harness with the regulator intact and after getting the new wiring harness I just cleaned the regulator up but didn’t remove the isolators and the one that I am holding was missing and I found it later on in all my “stuff”. I feel sure that at some point in the last 56 years I probably had to change the regulator and when I did, I installed the isolators the wrong way. Thanks again, Lamar
Edited by PLS on 12-04-18 03:21 PM. Reason for edit: No reason given.
VIN 58
Loc: ct
Reg: 03-23-10
12-06-18 02:58 PM - Post#2753654
    In response to PLS
Lamar thank you very much for posting this because i had a problem with mine. Sure enough those were isolators were in wrong. I had a clicking sound coming from the regulator when i connected the battery. Now no clicking again thank you very much. Vin
PLS
PLS
Reg: 06-07-12
12-06-18 06:27 PM - Post#2753679
    In response to VIN 58
Vin, you are more than welcome and I'm just glad when I am able to help, I sure get plenty here , Lamar
Execution time: 0.089 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:29 AM
