Username Post: point-of-use water heater        (Topic#354178)
LtFrankDrebin
LtFrankDrebin
Loc: Coopersburg, PA
Reg: 01-25-01
12-02-18 11:43 AM - Post#2753106
A customer wants an under-sink 2gal water heater installed because they want instant hot water in the morning. Can I use the hot water supply to supply the water heater? Instructions say to connect to cold water supply.
'56 210 Townsman wagon 6cyl/3spd OD | '58 Impala Sierra Gold 348
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
12-02-18 12:48 PM - Post#2753109
    In response to LtFrankDrebin
Unless you plan to have a third valve just for the new heater, you have to use the hot. The supplemental heater won’t run much, but it will meet the need until the primary feed dumps the cooler water from the line and it will all be hot.
Greg
'00 Explorer XLT 4.0 V6 Auto
DECEASED
12-03-18 06:47 PM - Post#2753254
That's almost exactly what I did when I installed a point-of-use heater for the same purpose. The only difference is that I used a tankless heater instead of a tank type. I still get instant hot water, but I'm not consuming power to keep the tank hot between uses.
LtFrankDrebin
LtFrankDrebin
Reg: 01-25-01
12-03-18 09:06 PM - Post#2753275
I wish the customer went with a tankless type.
Execution time: 0.104 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:23 PM
