Username Post: Speedometer issue & removal 1964 Impala        (Topic#354175)
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
12-02-18 09:47 AM - Post#2753085
Good Day all,
A month before my scheduled ankle surgery, my car blew a head gasket. I replaced the engine with a crate 350HO from Chevy Performance. I had a shop down the street do the install and they delivered it to my house but at that time, I had already had the surgery so I can't walk, or push the clutch in to drive my Impala.
My father came in town for Thanksgiving and he agreed to take me for a short cruise in the car to test drive it. It ran awesome but we noticed a slight clicking sound and noticed the speedometer was jumping around some at certain speeds. We also noticed the odometer was not spinning. I didn't have this issue prior to the engine replacement and wanted to get your opinion on the cause and how to go about fixing the issue.
The new engine is a more modern 350 with votec heads which required a new flexplate. New flexplate also required a new bellhousing, clutch and starter. I'm thinking maybe the speedometer cable got kinked somehow during the installation of those components but not sure.
What would cause the clicking sound in the instrument cluster and why would the odometer stop spinning? Could it be a problem with my instrument cluster as opposed to a damaged speedometer cable?
I appreciate everyone's input and hope your weekend is going well.
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
Edited by kingkreeton on 01-14-19 05:34 PM. Reason for edit: No reason given.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
12-02-18 10:26 AM - Post#2753095
    In response to kingkreeton
I would remove and reinstall cable ends sounds like it not fully engauged .Usually you can just unscrew one end and spin it a tad and it will engauge in the gears
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
12-02-18 02:14 PM - Post#2753114
    In response to 69_BOWTIE
That’s good advice, but if that doesn’t work, it could be old grease in the cable or the speedometer.
Member #2194
junky
Loc: Northeast CT
Reg: 06-27-10
12-02-18 08:05 PM - Post#2753136
Clicking is usually caused by a broken strand of wire in the bundle that makes up the speedometer cable. You have to remove it from the cable sheath, and then wipe it through a cloth to find the broken cable wire. They are not repairable, so just buy another cable, and install it. Universal cables are available at the auto parts stores, and you cut it and put a new end onto it. Reinstall, and you should e good for another 50,000 miles. Once you get it working, check your speedometer for accurate reading with a GPS.
omarine
Loc: San Diego
Reg: 06-29-15
12-03-18 07:43 AM - Post#2753160
same happened to my speedo - it usually occurs when flipping to a new digit for example 29,999 to 30,000.
In my case I got one rebuilt, that original grease in there hardens and must be broken free, cleaned and relubed.
drove with needle jumping around for a while in hopes it would un-stick itself.
found a good builder on ebay - I think I paid like $150 or so after sending him back mine.
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
12-03-18 10:36 AM - Post#2753186
    In response to omarine
Wow, good call. Mine is stuck there at 59,999. I'll see about making the speedo cable adjustments first. If not, does anyone know who rebuilds these things nowadays?
Shane
Shane
64 Impala SS:
4 Speed Muncie
55 Shaker
Loc: north central IL.
Reg: 03-13-06
12-03-18 11:00 AM - Post#2753190
Shane, here's the one I used in Howell Mich. with no complaints. https://www.bobsspeedometer.com/1/120/index.asp
Brian
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
12-03-18 12:03 PM - Post#2753198
    In response to 55 Shaker
Thanks for everyone's responses. I hope to be healed up enough to climb underneath and see what is going on. I'm going to be replacing my dash harness soon so that may be a good time to send my cluster off for a refresh so I don't have to take things apart again.
Shane
64 Impala SS:
4 Speed Muncie
omarine
Loc: San Diego
Reg: 06-29-15
12-03-18 12:20 PM - Post#2753200
Shane, with the 59,999 miles, my guess is the odometer gears are stuck.
I will look up my emails for the guy I used for rebuilt speedo.
good idea to replace wiring while already back there..
cheers
Oscar
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
12-03-18 03:15 PM - Post#2753223
Most of the time it's the little plastic piece that holds the speedo rollers in place. It's on the bottom of the mileage gear set.
I need to take mine a part and fix it as well.
I have fixed several in the 67-72 Chevy trucks over the years.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
12-03-18 03:40 PM - Post#2753230
    In response to Andy4639
Sounds like a good opportunity to make a "How to" write up so you can show us how to do it. I would be afraid I couldn't get the cluster back together once I had it apart. I hope that it is something I can fix as I just got a $400 quote to send it off for repair/refresh.
Shane
64 Impala SS:
4 Speed Muncie
Fossil_Fuel
Fossil_Fuel
Loc: Minnesota
Reg: 09-11-07
12-03-18 03:45 PM - Post#2753231
Mine had same problem at 49,999. They are not that hard to fix. Pop out the little plug and lube it with some light oil. I flushed it with WD40 then drained and put in a little electric motor oil, then replaced the plug.
I bench tested before and after with electric drill and the difference is dramatic. It’s just the grease getting old and trying to turn the next digit. Makes the Speedo needle jumpy and no turning of the odometer.
Google it for a good article. See pics below:
Attachment: 582CEEC3-4F1B-4E00-8DAB-D4FA9F696635.png (814.32 KB) 48 View(s)
Attachment: BE79FBB0-9E27-47F4-9D3D-5DACE6FCB893.png (1.01 MB) 33 View(s)
Attachment: 17D3E66B-2D08-4C91-9D30-F4929F2441F3.png (516.18 KB) 28 View(s)
1964 Impala SS 327/300 since '76
1967 Impala SS 327 Triple Black Hardtop in the works
1967 Impala 327 Bench Seat 4-speed
http://craigaacars.shutterfly.com/pictures
Edited by Fossil_Fuel on 12-03-18 03:50 PM. Reason for edit: No reason given.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
12-03-18 03:50 PM - Post#2753232
    In response to Fossil_Fuel
Which plug are you referring to? Where the speedometer screws into the instrument cluster?
Shane
64 Impala SS:
4 Speed Muncie
Fossil_Fuel
Fossil_Fuel
Loc: Minnesota
Reg: 09-11-07
12-03-18 03:54 PM - Post#2753233
See the pictures I added.
Or google “55-72 Chevrolet speedometer Repair”
Ecklers posted a how to article many years ago with good pictures.
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
12-03-18 04:22 PM - Post#2753236
Awesome, thanks for that.
Shane
64 Impala SS:
4 Speed Muncie
65_Impala
Reg: 12-29-02
12-10-18 12:19 PM - Post#2754069
My 65 did that. I had to take it apart until I got to the shaft holding all the number wheels. I then had to pry the washer on the end a little until the wheels were looser on the shaft. They were bound so tight it didn't matter how much cleaning or oil was applied. They simply couldn't spin free enough to turn multiple numbers at once. Once I did that it worked great, until I replaced the cluster with electronics that is.
gfm64
Reg: 09-06-16
12-10-18 04:32 PM - Post#2754099
I had an old car do this. I found out the cable had rust in it. It made the speedometer do the same as yours. I found a tool that fit on the end to pump grease into the cable. After that it worked like new. That was back in the 70s so I cannot remember what the tool was .
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
01-14-19 06:47 PM - Post#2757382
Well I have reached the point of my Dash Harness replacement project where I needed to remove my console and instrument cluster for easier access to run the wires. I have never removed either before and the job wasn't that bad. I decided I would try and open up the instrument cluster and lube up the speedometer while I was at it. I mentioned before about doing a write up on it so I took a few pictures and some notes that will hopefully help anyone else looking to try and do this job themselves. Please note, I do not have a padded dash so there may be additional steps for cars with padded dashes. Prior to starting this job, I had already disconnected the instrument cluster harness and speedometer from the back of the cluster. I recommend doing this prior to unscrewing the console as it is heavier than I thought it would be and you really need both hands to remove it without scratching anything else (ie. steering wheel or your dash). I also had the seats removed, probably not necessary but it certainly makes it easier when trying to unplug the wiring harness from the instrument cluster.
First I dropped the column. I removed the small cover below the steering column.
Cover Below Steering Column
I then removed the clamp by the firewall that holds the column to a small tang on the firewall.
Steering Column Clamp by Firewall
Then loosed the clamp holding the steering column in place near the dash.
Steering Column Clamp by Dash Board
That allowed me to drop the steering column down about 3 or 4 inches. It was enough that I didn't have to remove the steering wheel, but then again, I have a smaller diameter steering wheel than the stock size so removing the wheel may still need to be done.
I then started removing the screws that hold the console in place. I didn't count how many there were but it was probably 8 or so.
Screws Around Console
After all the screws are removed, the console and cluster came out by rotating the top back towards the front of the car and then I pulled it out. It wasn't too bad but I was trying be very careful not to scratch anything and like I said before, it was heavier than I anticipated.
Console and Instrument Cluster Removed
Once I have the console/cluster out, I placed it on a towel to see how to separate the two.
Console and Cluster removed attached
I recommend doing this on the ground due to the awkward weight/length combo. Again, it was held together by small screws that were easily removed.
Screws attaching cluster to console
Once I had the console and instrument cluster separated, I took the cluster to my work bench to determine whether or not I felt comfortable trying to open it up to investigate the speedometer issue I was having. I saw the clear plastic lens was held on by these small reusable metal clips that looked like I could get them out and reinstalled without breaking them so I rolled the dice and tried to open up the cluster. All the clips came out easily with needle nose pliers and that left the clock adjustment lever. There is a very small flat head screw that has to be removed for the handle tip to be removed.
Clock Adjustment Lever
Clock Adjustment Lever Screw
After removing the clock handle tip, the glass pulled off.
Glass Removed from Cluster
I was able to access the speedometer assembly, lube it up and spin it enough times to ensure the odometer worked.
Speedometer Removed from Cluster
I then took the opportunity wash the lens and cluster assembly with soap and water. I used a toothbrush to clean the small silver sections on the ends and it worked really nicely. I couldn't believe so much grime was built up in there. It's by no means brand new looking, but it's definitely a vast improvement.
Console Glass Cluster Seperated
I put everything back together and buttoned it up. I won't reinstall the console/cluster combo until after I finish my firewall pad and dash harness replacement. Hopefully some others in the future will find this post helpful. Once I get everything reinstalled, I post whether or not I'm still having issues with the speedometer. If so, then I'll be replacing the speedometer cable.
Shane
64 Impala SS:
4 Speed Muncie
Edited by kingkreeton on 01-14-19 06:55 PM. Reason for edit: No reason given.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-15-19 05:36 PM - Post#2757494
Nice job sir! I wished when I had mine out I had know the mileage wheels weren't working and I would have fixed them but oh well. Next time I have to pull it they will be fixed.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Execution time: 0.08 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:39 PM
