49betty
Reg: 12-01-18
12-01-18 04:53 PM - Post#2753030
Hi. First post so not sure if it will work or go where it should. Looking for information on identifying casting numbers on 50s transmissions. I want to keep column shift but want to maybe upgrade the dif to improve highway speeds. Would appreciate any and all advice.
carolina chevrolet
Reg: 11-12-18
12-01-18 06:33 PM - Post#2753036
In response to 49betty
Welcome. There's some info on casting numbers in this thread.
49betty
Reg: 12-01-18
12-01-18 07:06 PM - Post#2753040
In response to carolina chevrolet
Thanks for the road map to those casting numbers. The trannys Ive been looking at are later 50s with open driveline. Ive been all over google looking but apparently in the wrong place.
DECEASED
12-01-18 09:35 PM - Post#2753050
There are two ways to go, depending on how much of a gearing change you want.
Your stock rear axle ratio is 4.11. If 3.55 is enough of an improvement, you can swap the torque tube assembly from a 50-54 Powerglide car, which is a total bolt-in. This is a very easy swap and can be done in just a few hours.
If you want taller gearing than 3.55, you will need to convert to open drive, which means replacing the bellhousing, transmission, and rear axle. You will also need to replace or modify the transmission crossmember to accommodate the mount on the open drive trans and relocate the parking brake linkage. This will take considerably longer than the torque tube swap, so be prepared to have the car out of service for several days.
49betty
Reg: 12-01-18
12-02-18 01:14 PM - Post#2753113
Thanks Ray. Ive looked high and low for a powerglide rearend but up here in the cool north alberta its hard to find. Winter here so was thinking I had time for a longer down time. Ive located some newer open drivline trannys but wanted to see if I could tell what they were from the casting numbers and try to get a handle on the difficulty in getting the shifting levers and clutch working properl. Thanks again Robert.
49betty
Reg: 12-01-18
12-02-18 01:17 PM - Post#2753115
Havent had any luck identifying the transmissions but I believe they are Saginaw or maybe Muncie from late 50s or early 60s. they have 7 bolts on the side cover.
DECEASED
12-03-18 06:13 PM - Post#2753256
A 7 bolt cover will usually mean a Saginaw trans, used 66-up. There was also a 7 bolt Muncie 3 speed from 69-on, but those are rather scarce and would definitely be overkill for your application (they were originally intended for big block V-8s). The Saginaw is a better trans than the 4 bolt (stronger, quieter, and with a synchronized 1st gear), but will need more work in order to hook up the column shift linkage. Otherwise, installation is the same as for the 4 bolt.
You can keep your existing clutch with either a 4 bolt or 7 bolt trans, but the clutch linkage will need a bit of work because of the fork angle coming out of the bellhousing. The difference will be evident when you compare your present bell with the replacement part.
49betty
Reg: 12-01-18
12-03-18 07:41 PM - Post#2753271
Thanks raycow. Im leaning towards the new tranny with syncro. It might take me a while to figure it out but if its been done before that gives me hope. Still looking for a power glide rearend though or maybe a S10 rearend.
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
12-03-18 08:44 PM - Post#2753279
Don't forget the S10 must be a Blazer 4x4. Try to avoid the 1994 model due to a change over year, is what I've heard. Not a bad swap at all. I put mine in with a Chassis Engineering rear suspension kit.
Johnnie
1950 styleline deluxe sports coupe, 350 cid, TH 400, nova rear end. Gen IV Vintage air. SOLD!
1953 210 4 Door, 235 with Powerglide. All original except for the 1954 hood bird.
John 3:16
drew1987
Loc: Rochester, New York
Reg: 02-23-14
12-03-18 08:56 PM - Post#2753282
In response to Cruzin Okie
49Betty,
welcome! this is arguably the best forum on the web, regardless of make and model. Hopefully you find all you need here. I have loved my 1957 chevy housing with 1960ish 3.08 gears, given that I have enough ponies to turn them. The 3.55:1s I had with my stock 235/3spd/torguetube were good in that situation. Camaro and S10 are wonderful options, as pointed out too. If you dont stay with a torque tube, but you keep stock springs, please note that the pin that located the spring perches is NOT centered... the rear in these cars stock was on a hinge of sorts to make up for the lack for the torque tube to move for and aft. that said, the perches on whatever you put in will need to be drilled to match. Maybe say 55-62 chevy rear ends dont need the perches moved inward, but I did on mine, as I could see forgoing 20% of the total contact of the rear end to the springs to avoid a little welding
best,
drew
Edited by drew1987 on 12-03-18 08:56 PM. Reason for edit: No reason given.
49betty
Reg: 12-01-18
12-04-18 05:58 PM - Post#2753393
In response to drew1987
Good advice thanks. Up here in Alberta old iron is hard to find. Ill have much better luck looking for the S10 rearend. Ive located a couple rearends from 85 or 87 S10 but they are 2 wheel drives. What is the difference between them and 4WD. Is the 2WD not good for this rearend swap?
12-04-18 07:06 PM - Post#2753407
The 2wd is to narrow.
29-41, 42-48, 49-54 Moderator
1962 Ranchero Purchased 4/2017 221 V8 Auto. Sold 9/20/18
2013 F150 |
49betty
Reg: 12-01-18
01-03-19 03:26 PM - Post#2756495
Ive located a 4wd S10 blazer with gear about 3.42 I think. Out of an 87/88. Noticed the drive shaft is about 1 inch off center. I remember reading a post about this but cant remember if it was an issue or not. Cant find the post. Im sure there is a way to search for it....
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
01-03-19 06:00 PM - Post#2756512
Not an issue.
Bel Air kiwi
Reg: 04-24-14
01-03-19 11:05 PM - Post#2756531
In response to Mike JW
Hi, to expand on what JW was saying. It is unusual for the driveshaft to enter most rear axles on the vehicle centerline. A crown wheel and pinion gear set require an offset.
If you want to find the middle of a rear axle measure in from the same place each side. eg axle flange or backing plate etc.
I remember seeing a 32 hi-boy roadster where the clown who built it went from the driveshaft line and his rear wheels sat about 1 1/2" out from one side to the other.
He used to call my good friend Dave "rubber ruler" which is a pretty harsh insult to a pro builder. So I waited for a big crowd before saying out loud, "Your car must be for circle track racing, why else would you build in chassis stagger?"
That amount of offset is common and is split between the front and rear universals in the vertical plane. Not an issue. They probably deflect more than that horizontally in normal suspension movement. Universals don't like big angles but the most destructive is no angle at all as they can quickly chatter the bearings to death
Cheers Kiwi
"They made a desert and called it peace." Tacitus |
Edited by Bel Air kiwi on 01-03-19 11:11 PM. Reason for edit: No reason given.
49betty
Reg: 12-01-18
01-04-19 04:38 AM - Post#2756540
In response to Bel Air kiwi
Thanks for advice. I was thinking it wasn't a problem but wanted to make sure. The guy I was getting it from told me that Mopar put some of their engines off center in their cars to clear the steering box? Thought that was a bit weird.
