Username Post: Door Sticks        (Topic#354164)
TYTILIDIE
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
12-01-18 03:33 PM - Post#2753012
My passenger side door sticks shut most of the time but not always. I'd say its about 80/20. If you are in the car, you have to pull the handle up as normal but you have to give a pretty good shoulder bump to get the thing open. It sits pretty straight, I have played with the striker a million times, there is a wear mark on the top of the striker on the door side which would seem like a plain indicator but again, nothing seems to help. I am out of ideas. Tried the search which brought me no goodies.
Any thoughts?
Me
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
12-01-18 03:38 PM - Post#2753014
    In response to TYTILIDIE
Put some masking tape in the area where you think the problem is to find exactly where it’s striking wrong, then gently close the door.
Member #2194
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
12-01-18 06:51 PM - Post#2753033
You might try this. (With the door open does this spin freely when the thumb button is pushed in?)Lamar
Attachment: IMG_5860_-_Copy.JPG (360.63 KB) 6 View(s)
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
12-02-18 09:54 AM - Post#2753086
    In response to PLS
It does spin freely.
I am going to try the tape trick later today. I have adjusted as much as I can, not sure what to make of this.
Me
12-02-18 10:04 AM - Post#2753090
My 46 PU stuck when I got it. Found where it was rubbing and used a file to free it up.
29-41, 42-48, 49-54 Moderator
PLS
PLS
Reg: 06-07-12
12-02-18 10:27 AM - Post#2753096
If had not I could give you a easy solution. Hopefully the other suggestion will do the trick for you. Lamar
Spas602
"2nd Year" Platinum Supporting Member
Spas602
Loc: Phoenix, AZ
Reg: 08-30-17
12-04-18 05:49 AM - Post#2753301
The door striker on the body is going out. I replaced the strikers on both my cars when i had the same problem. No issues with sticking since. Hope this helps.
My CT Build Page:
http://chevyta.lk/Spas606_ImpalaBuild
TYTILIDIE
TYTILIDIE
Reg: 10-21-15
12-05-18 07:47 PM - Post#2753540
    In response to Spas602
Turns out I am a bonehead. I was playing with the striker this afternoon and noticed the spring loaded pin was stiff. I almost got out the lube but went to double check the driver's side. Turns out, the driver side was brand new and I thought to myself, "why would I put one new striker on and not the other"? So I went to my parts boxes and what do you know, I find a brand new right hand striker in the box. I installed it and all is well. Kind of embarrassing but it happens to the best of us I guess.
Me
DonSSDD
DonSSDD
Reg: 08-21-01
12-06-18 03:47 AM - Post#2753586
Thanks for being honest, its always nice when we find out something was fixed and the solution.
If we start a forum for "dumb" things we all did, it would be overflowing in no time, including a list of "spare" parts we have left over from buying things twice because we forgot we bought it already.
Member #2194
Execution time: 0.193 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:23 PM
