Username Post: HEI UPGRADE        (Topic#354143)
R8ROB
Reg: 08-14-17
11-30-18 09:28 AM - Post#2752895
Good morning I recently switched to hei on my 65 2dr ht. I have a pink wire that was going to the coil. Will that now be my power wire going to the HEI distributor? When key switch is in the off position it shows 1.2 VDC and when the ignition is turned on it shows 0.0 VDC on meter. I recently upgraded to AAW 510360 classic updated kit.
Edited by R8ROB on 11-30-18 11:29 AM. Reason for edit: No reason given.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
12-02-18 11:11 PM - Post#2753144
    In response to R8ROB
The pink wire in the engine harness that says 12v ignition is the feed to the "batt" on the hei distributor. Should have a a full 12 volts with the key in the "on" postion. What did you have in the car before and how did you have it hooked up?
Donny
R8ROB
Reg: 08-14-17
12-18-18 02:15 PM - Post#2754940
    In response to aawtech
Looks like it wasn't fully making contact on the opposite end. that took care of the issue.
Execution time: 0.116 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:41 AM
