Username Post: 1964 PG to TH350        (Topic#354140)
Jim.Biron
Jim.Biron
Loc: Monterey, TN
Reg: 04-10-08
11-30-18 07:16 AM - Post#2752879
What do I have to change to make the above happen. Linkage I know and that is available at several places (I have a console shifter). Trans crossmember? Drive shaft? cooling lines? etc...
www.HudsonValleyCruise.com
DECEASED
12-02-18 10:54 AM - Post#2753101
    In response to Jim.Biron
If you get a short TH350 (about 27"-28" overall length), the length, output shaft splines and mount location are the same, so no driveshaft or crossmember mods are needed. Cooling lines are a maybe if you can't re-bend the existing ones to fit. Don't forget to include the TV cable with the shift linkage.
Jim.Biron
Jim.Biron
Loc: Monterey, TN
Reg: 04-10-08
12-04-18 08:18 AM - Post#2753317
Thanks Ray.
Execution time: 0.139 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:36 PM
