Username Post: 97 blazer 4.3        (Topic#354137)
KempaSwe
Loc: Sweden
Reg: 11-30-18
11-30-18 03:37 AM - Post#2752861
I just bougt a s10 blazer 4.3 -97 that wont start. First thing that I found was that the fuelpump was broken. After I changed the pump it will just run for about 2 sec and when I crank the engine the pump wont start so I get no fuel. Do you need a remote for some anti theft to START? He had no remote to the car and the battery was totaly dead when I got the car. And this car dont got any chip in the key.
If there is any security system, can I bypass it in some way?
Senior Chevytalk Moderator
11-30-18 04:44 AM - Post#2752865
    In response to KempaSwe
Welcome to the board. The theft alarm should deactivate when a key is used to open the door. Does it have all power equipment? Have you verified fuel pressure is above 55 psi? What does fuel pressure do? Was any other maintenance done to it? Do you have an ODBII scanner?
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
11-30-18 06:16 AM - Post#2752878
Did you get the upgraded connector with your pump? You need to follow the rewire instructions for your model. Better yet, what brand pump did you get? AC/Delco or Delphi only. If you got a lifetime warranty pump...great. You can replace it every 6 months....(sarcasm) Check the link for proper fuel pressure testing...
https://www.s10forum.com/forum/f107/how-to-che ck-r...
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
Execution time: 0.172 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:33 AM
