Username Post: Gm hei wiring diagram in 59        (Topic#354134)
Hourston
Reg: 01-24-17
11-29-18 06:21 PM - Post#2752835
Hey guys about to put a gm big cap style hei in my 59 impala
I have done it before in other cars but the years have past and i cant seem to figure it out for the 59.
I dont know yet if it will even fit with the fire wall clearance.
Any help appreciated
ARTEMIS1759
ARTEMIS1759
Reg: 04-12-09
01-31-19 12:29 PM - Post#2758674
    In response to Hourston
I can't help you to a T. But, I have done this on my 58 and Dad's 59. I believe you are looking for the green wire to the coil, get a 10 pink wire and that hooks to the pink wire on the cap. The other goes to the S terminal on starter. To verify, the best way is get a manual for a vehicle with HEI and check the wiring diagram. Then cross reference to the 59 diagram. That's how I always do it.
To those who dance to the beat of a different drum and dare to make they're dreams come true...
Edited by ARTEMIS1759 on 01-31-19 12:30 PM. Reason for edit: No reason given.
4spd409
4spd409
Loc: Sherwood ND
Reg: 10-10-02
01-31-19 02:08 PM - Post#2758681
    In response to ARTEMIS1759
The s terminal on the starter activates the starter so that won't work. You need to find 12v ignition power for the bat terminal on the hei. You can't use the power wire from your old system as it has a resistor wire and will not provide 12v. Should be able to find a spot on the fuse box. Make sure that it has 12v while you are cranking the motor also. Use a 10 gauge wire. The other terminal on the hei is for a tach.
61 Impala Bubbletop
ARTEMIS1759
ARTEMIS1759
Reg: 04-12-09
01-31-19 02:27 PM - Post#2758682
    In response to 4spd409
It's been a couple months. Not near my car. Thanks for chiming in. I got mine hooked up right. Like I said I just crossreferrence wiring diagrams..
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-01-19 06:58 AM - Post#2758733
On my '63 there was NOT enough clearance for the large (1 inch more in diameter) cap. I've read that some other '63s do fit. Something to check.
There are 'small cap' distributors w/o points. A separate coil is required. This set up looks very original. It's what I have on my '63 sbc.
Pete
ARTEMIS1759
ARTEMIS1759
Reg: 04-12-09
02-01-19 07:34 AM - Post#2758736
    In response to japete92
I am going that route because of clearance issues. It works but everything is too close.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
02-02-19 09:57 AM - Post#2758821
A stock distributor with pertronics works great.
Member #2194
02-02-19 11:27 AM - Post#2758823
There is no place on the fuse block that provides switched power during cranking.
Run a larger gauge (at least 12 gauge) wire from the ignition switch directly to the HEI distributor "bat" terminal and splice the tan wire, that was on the switch, into the new wire. Tape back, or remove, the white wire that went to the coil.
Edited by acardon on 02-02-19 11:33 AM. Reason for edit: No reason given.
ARTEMIS1759
ARTEMIS1759
Reg: 04-12-09
02-02-19 09:52 PM - Post#2758870
    In response to acardon
That's what I thought. I ran a bigger wire in place of the original coil wire. Thanks for clarifying. Had me questioning how I did it. Lol.
AZRodney
Reg: 05-20-15
03-14-19 10:21 AM - Post#2762068
On mine with a zz4 crate engine I was having some missing at higher RPM it seamed like. So I also ran a an 8 ga wire from the battery back to the starter switch and 10 ga to the HEI. Seams like everything in the car originally was fed off a 12 ga wire from the battery and from what I read was most people suggested 12 or 10 ga to the HEI. I also cleaned up a bunch of wiring and added some additional grounds so not sure what actually helped but it is running much better now.
Execution time: 0.111 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:47 PM
