Username Post: Flat cam        (Topic#354130)
J C
J C
Loc: Orange Co. Calif
Reg: 04-17-04
11-29-18 01:13 PM - Post#2752804
I have a 86 chevy g30 1 ton van. GM crate 350 with approx 175K. When i got it back 4 yrs ago after smogging, it idled horrible. I did not have a tool to adj. the idle mixture so I just lived with it. Within the last 4-6 mo I have had choke prob making it run fast each start up. Also diesels. Some times it backfired. Goes down the road fine. Took it to a smog shop to hopefully get things adjusted & smog ready. He said I had a flat cam. Timing is now set now at approx 14-16 degrees. Idles a little fast & still diesels and a little hard to start. Raining here so I haven't messed with it to get it back. He did not pull anything off so how can he or I tell if the cam is indeed flat? Like I said once off idle it runs fine. This is a work van bone stock. My hearing is poor so I can't hear slight ticking (lifter, rocker arm) or the like.
69RSZ28 71 Chevelle 79 Silverado 24K mi.
11-29-18 05:02 PM - Post#2752827
    In response to J C
To properly diagnose worn cam lobes, the rocker covers should come off and comparative valve lift measurements should be taken, otherwise a lot of guesswork is forthcoming.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-29-18 05:48 PM - Post#2752831
65_Impala
Reg: 12-29-02
11-30-18 08:03 AM - Post#2752885
    In response to J C
It a cam lobe has gone flat then the rocker clearance would have opened way up and it would be tapping quite loudly.
J C
J C
Reg: 04-17-04
11-30-18 10:20 AM - Post#2752898
    In response to 65_Impala
Thanks for the info. I kinda though that there would be a more positive way to determine it or a audio noise. Plus the van runs very good once it gets off idle. I'll have someone listen to it due to my hearing problem. Taking the valve covers off the van is not real simple with a clearance prob and numerous hoses that would have to be removed.
11-30-18 11:33 AM - Post#2752906
    In response to J C
65_Impala is right, a totally flat lobe will cause rocker clearance, but partially worn the lifter can pump up enough to close up the rocker clearance.
IgnitionMan
Reg: 04-15-05
11-30-18 02:35 PM - Post#2752922
I don't ever remembering any significant rocker tap when hydraulic cams have lost lobes, only intake, and/or exhaust note changes.
65_Impala
Reg: 12-29-02
11-30-18 05:45 PM - Post#2752939
The wear that a lifter could compensate for is maybe 0.040". I'm doubting that less than 0.040" of wear would cause idling issues but it would likely lead to the cam wearing further rather quickly.
Now, if a 0.28" lobe wears half off then you've got around 0.24" of rocker to valve clearance. Anyone could hear that clicking.
Besides, I helped replace a cam in an engine not to long ago after diagnosing a badly worn lobe. It was VERY obvious there was an issue just listening to it.
11-30-18 07:11 PM - Post#2752947
Interesting point, pretty sure the hydraulic lifter has more than .040 travel, gonna try and find out what it is, fun. Ok did some online research, Ford is about .120 travel, non ls lifters are about.090. I am sure there are different designs based on performance aftermarket stuff. So, a lobe that was really worn down would certainly result in excess valve lash.
Edited by Shepherd on 11-30-18 07:32 PM. Reason for edit: No reason given.
IgnitionMan
Reg: 04-15-05
12-01-18 01:21 AM - Post#2752962
There's where we all mostly differ, I don't let them get bad enough to make a bunch of noise, I just fix 'em first.
Also, the button usually sits close to the top of the plunger travel, so, not a lot of clearance is there to begin with when lobes go flat.
12-01-18 06:20 AM - Post#2752967
    In response to IgnitionMan
Yeh, seems we would all get plenty of notice before you had no lobe! Lol
IgnitionMan
Reg: 04-15-05
12-01-18 07:30 AM - Post#2752975
Fully agreed, sir. Worked just that way for at least a century, so far.
65_Impala
Reg: 12-29-02
12-01-18 11:07 AM - Post#2752994
LOL, the one I fixed was driving down the road not making a sound and the tick came on really quickly. It was banging away very loudly by the time it went 3-4 miles to get the car home. The cam and lifter feet are only hardened to a certain depth and once you wear through that hardened layer the rest wears away rather quickly.
IgnitionMan
Reg: 04-15-05
12-01-18 11:24 AM - Post#2752996
Sounds like the oil mist lubrication was insufficient to support the few thousandths of hardening on the lobe, and lifter face.
Probably some sort of full synthetic, or partial synthetic snake oil "lubricant" that did its job, fail.
Seen that so often, and, it has never been funny.
Who knows, who cares, cam needed replacing anyway, just another engine fix it job, tick or not.
12-01-18 01:34 PM - Post#2753008
A couple of bad cam sbc engines I ran into, wiped the bearings out also that metal get all over the engine.
IgnitionMan
Reg: 04-15-05
12-01-18 05:04 PM - Post#2753025
Yup, seen that as well.
Only cams I have seen that aren't as succepable to lobe/lifter wear away in a mist oiling system, are roller cams. They don't require a lot of oil mist to be happily lubricated.
J C
J C
Reg: 04-17-04
12-01-18 07:16 PM - Post#2753035
    In response to J C
Based on comments I suspect that the smog guy who worked on my van was just guessing. The idle problem has gone on for about 3 yrs now and not gotten worse & no loud ticking. I just haven't had the time to work on it. The only thing that has changed is the timing. Seems to run better at approx 14degrees. Doesn't seem to have as much power but is ok. No dieseling or backfire now. Don't know if the balancer has slipped. Bought a tool to adj the fuel mixture. Package says it's correct for my year but it doesn't seem to turn the screws.
IgnitionMan
Reg: 04-15-05
12-02-18 01:24 PM - Post#2753111
    In response to J C
It just sounded like your smog guy didn't pull the valve covers and fire it up to take a look at the rocker action. Hard to make an "edumacated" guess if that isn't done when a flat cam, or other valve issue is suspected.
That engine is well within the bounds of emissions tuning specs, and although "throwing more ignition timing at it" might help one running parameter, changes can make the rest a giant adverse running issue.
65_Impala
Reg: 12-29-02
12-03-18 11:42 AM - Post#2753196
    In response to J C
It's not too likely to be a lobe if it's been about the same for 3 years.
Are you attempting to describe a new spec oil that doesn't have enough extreme pressure additive in the supplemental additive package, ie zinc as it's commonly called? Because that's what I suspect, an oil blended for a roller cam engine which is unsuitable for use with a flat tappet cam. Doesn't matter what kind of oil, the wrong blend of synthetic or conventional would both do the same thing.
IgnitionMan
Reg: 04-15-05
12-03-18 06:13 PM - Post#2753252
Pull the valve covers, check things out, fix what's broke.
Simple as that, stop trying to fault my every word.
65_Impala
Reg: 12-29-02
12-04-18 12:32 PM - Post#2753348
What's your problem exactly? You were posting comments diagnosing why I was replacing a cam.....
IgnitionMan
Reg: 04-15-05
12-04-18 05:07 PM - Post#2753379
No, I only added info to help people, you did what you always do, began to cut what I posted apart, as you always do.
Can't you just help, and not pull whatever personal problem you have with me out for everyone else to be forced to endure.
This topic has run its course.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
12-05-18 08:26 AM - Post#2753458
    In response to J C
Maybe I am missing something here.
Why do you think you have a flat cam? Because some high school auto tech that runs a smog computer said so?
Forget that. If it is hard starting, like binding when you are turning it over, and dieseling, just retard the timing about 5 degrees.
If you have a flat cam, check for a miss my pulling plug wires one at a time. If you do, indeed have a miss, there is a problem somewhere. I just refuse to accept that you have a flat cam based on the smog "adjustment". Doesn't make any sense.
If you don't have the skill set to check for a miss, take it to a good mechanic. Let him find the problem. If you DO actually have a flat cam, by the time you pay for that to be replaced, you can buy a good WTO 350.
I would not recommend replacing your engine if it was something that you built, and wanted to keep, but, by your post, there is nothing special about your engine. 350 engines are a dime a dozen. Internal engine work is very expensive.
With 175K on that engine, when you replace the cam, you are looking at lifters, cam gears, chain, gaskets, oil and filter, labor. You are talking about over $1500 just to replace a cam on a worn out engine. The next thing to go are the rings, then the mains and rod bearings. It goes on, and on, and on.
At my age, I look for the simplest solution to a problem. I see a lot of fretting, and fighting here over a non-issue.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
12-05-18 09:28 AM - Post#2753465
    In response to beagrizzly
Well stated.
IgnitionMan
Reg: 04-15-05
12-05-18 09:50 AM - Post#2753469
Fully agreed.
65_Impala
Reg: 12-29-02
12-05-18 10:44 AM - Post#2753477
It's OK, it's not like you were purposely being an ignorant SOB bringing up synthetic oil only because I've previously posted how synthetic oil is superior to conventional or anything other nonsense like that. Obviously, you are completely innocent, LOL.
As I posted - the additive package in most oils sold for use in new engines don't support performance flat tappet cams any longer. At best, they might support a low lift, weak valve spring setup. The extreme pressure additives have been reduced since new engines don't have flat tappets any longer. It has nothing to do with the oil type.
IgnitionMan
Reg: 04-15-05
12-05-18 03:04 PM - Post#2753511
Can't you just help others, they don't deserve to hear all your hate towards me, nor anyone else.
J C
J C
Reg: 04-17-04
12-05-18 10:14 PM - Post#2753567
    In response to J C
I can't argue with anything that is suggested. I don't think I have a flat cam. The Van runs good when it is off idle. No miss or anything. I know the smog guy did not pull the valve covers because they are a pain in the butt. My thought at this time but first some history. Van started dieseling bad for a few weeks. Had to shut it off in gear to try to stop it. Nothing was changed to cause this. The choke started to stick on after every stop, even if only for a few minutes. Now the van will not idle at 6 degrees advance. It will not idle or run until approx 14-16 degrees. Could the dieseling have caused the timing mark on the dampner to have shifted. My understanding is the dampner is a two part assembly held together by rubber. If it could be the dampner I will have to pull the pully and see where the timing mark is in relation to the keyway on the dampner unless there is a better way or suggestion. Thanks again for everyones ideas
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
12-06-18 08:12 AM - Post#2753616
    In response to J C
Sounds to me like you may have a vacuum leak
YOUNG57
Loc: Tennessee
Reg: 12-06-10
12-07-18 10:44 PM - Post#2753817
    In response to aghaga
Bingo, I agree with a vacuum leak. probably a cracked vacuum hose or the carb mounting gasket.
Execution time: 0.106 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:25 AM
