Username Post: Rage gold over 2k primer ?        (Topic#354125)
57 Tomm
Loc: walnut creek, ca. 94597
Reg: 01-10-07
11-29-18 10:18 AM - Post#2752786
Fender has been epoxy primed and covered with 3 coats of 2k (within window time frame.) If I sand with 80 grit, will the rage gold adhere properly? There are still a few low areas, no more than 1/8” that need to be filled. Would polyester glazing putty be better?
57 Sport Coupe Ivory/Surf Green
11-29-18 08:34 PM - Post#2752843
    In response to 57 Tomm
Either would probably be okay. The glazing putty would probably have a better chance of sticking. But if you use the regular filler and it sands well and seems to be adhering well, it should be good to go.
1957 Cameo Carrier
Execution time: 0.248 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:31 PM
