Username Post: LS1 install and door lock questions        (Topic#354080)
blacky
blacky
Loc: Perth , Australia
Reg: 10-24-05
11-26-18 09:48 PM - Post#2752481
Hi guys, I am planning an LS1 and 4L60E installation in place of the 350/T400 in my Fleetline Aero , I am using a stock chassis and a front end similar to a Mustang 2 , anyone here done this conversion and can let me know what headers you used ? My car is RHD so I will need to modify whatever it is I buy , am thinking that either block huggers or shorty style will be the way to go ?
Also , the lock mechanisms in my doors are flogged out , the part the rod from the door lock slides into is just a round hole now so I cant lock or unlock the doors using the key , the rest of the mech is fine , I have had a look and cant see anybody repopping these items , is there a later model latch mechanism or something I can cannibalise parts out of to fix my units ????
"Jesus loves you " - which is GREAT if you are in church , but not so hot if you are in a Mexican prison !
11-27-18 08:37 AM - Post#2752519
    In response to blacky
The rod is flat on 2 sides. Here is a link.
https://www.chevsofthe40s.com/shop/search.lasso?ve...
29-41, 42-48, 49-54 Moderator
blacky
blacky
Reg: 10-24-05
11-28-18 06:04 AM - Post#2752632
Cheers Keith, the locks and rods are fine mate, the problem is where the lock rods slide into the door latch mechanism , seems to be a pot metal receptacle which has turned to dust and now the lock rods are turning in thin air - I tried building them up with knead-it , not sure if you mob get that stuff , its like a 2 part epoxy that is meant to be similar to metal , can be ground, drilled, tapped etc - it worked for a short time but the only real fix is going to be new door latch mechanisms or the bits the lock rods slide into. Trunk latch is a bit funky too but it doesn't seem they are reproed yet either
11-28-18 09:16 AM - Post#2752659
Ok I have a similar problem with my 48. PO used the wrong screw to hold in the lever and screwed up the threads. I bought a used latch assembly but haven't installed it yet. I could not find a new latch assy.
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
11-29-18 10:05 AM - Post#2752790
Ive done the conversion on a fleetmaster convertible with a mustang II front end
The kits are not very difficult with a minimum amount of welding. You have to measure the amount you want set back for radiator and firewall clearance.
BTW, Christ is with you no matter where you are; Paul was imprisoned in places that made present day Mexican prisons look like country clubs many times just because of his beliefs. Anyone in a Mexican prison or any other kind didnt get there because they were good people........
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
blacky
blacky
Reg: 10-24-05
11-29-18 04:28 PM - Post#2752828
Guess I will have to try and find a decent set of used ones, not an easy task in Australia
The other option I guess is remote locking but I don't really want to go that way if I can help it
Broo102
Broo102
Reg: 09-30-14
12-12-18 07:53 PM - Post#2754312
Fender headers are what you want. They extend into the fender well slightly outside the chassis. I used them. The only thing I didnt like was the portion of the pipe had to curl under the chassis a bit near the header connection.
Thanks!
Bru
John 3:16
48BOM8
Reg: 03-08-21
03-14-21 05:55 PM - Post#2816165
    In response to Broo102
Hi mate, did you get the Ls1 into your car? im chasing some information ..
Broo102
Broo102
Reg: 09-30-14
03-14-21 08:08 PM - Post#2816169
    In response to 48BOM8
Yes,
Let me know what info you need
Thanks!
Bru
John 3:16
Execution time: 0.176 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:55 PM
