Username Post: speed doesn't work        (Topic#354079)
jetboat36
Reg: 11-21-18
11-26-18 09:34 PM - Post#2752478
so i pull the speed sensor of the t case and test it out with a voltmeter and a drill the sensor work good. so why the speed still doesn't work ?
tcndeb
Reg: 04-18-04
11-27-18 07:20 AM - Post#2752509
    In response to jetboat36
on what?
'92 Full Size Blazer
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-27-18 09:23 AM - Post#2752527
You must be talking about a square body. All GMT400s use electronic speed sensors and you can't test them with a drill.
Jeff
jetboat36
Reg: 11-21-18
11-27-18 12:20 PM - Post#2752546
    In response to bowtie44s
on a 1998 k2500 is the one with 2 wire the tip is a magnet the one in the tcase. and yes you can test it out with a drill i did and i can see on the voltmeter the sensor work .....
jetboat36
Reg: 11-21-18
11-27-18 02:50 PM - Post#2752561
anyone got the wiring diagram ?
tcndeb
Reg: 04-18-04
11-27-18 03:11 PM - Post#2752563
don't have a schematic with me but that should have a vssb in the circuit after the sensor.
454cid
Loc: West Michigan
Reg: 02-18-12
11-27-18 03:13 PM - Post#2752564
What are you turning with a drill? I've never pulled mine, but looking at new ones online, it looks a lot like a crankshaft position sensor.
99 K3500 RCLB
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-27-18 06:32 PM - Post#2752580
    In response to 454cid
That is the part that has me confused.
I had some speedometer problems a few years ago. Here is the thread on how I tracked it down. Hopefully this helps.
Jeff
jetboat36
Reg: 11-21-18
11-27-18 10:10 PM - Post#2752606
is for testing the speed sensor since its a magnet at the tip because the sensor produce is own volt i used a dril and a bit make it turn and put the sensor close to it if the ac volt goes up sensor working and he did it ...
454cid
Loc: West Michigan
Reg: 02-18-12
11-27-18 11:20 PM - Post#2752613
Interesting, so the drill bit is a makeshift tone ring or reluctor. That still doesn't mean that it's sending a signal that means anything, although, I suppose it's a start.
99 K3500 RCLB
jetboat36
Reg: 11-21-18
11-28-18 12:15 PM - Post#2752682
i know but i know the sensor is good so what next should i check the speed sensor buffer box?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-28-18 04:47 PM - Post#2752719
Did you read the thread I linked you to? It should walk you through it.
Jeff
jetboat36
Reg: 11-21-18
11-28-18 07:32 PM - Post#2752737
yes i did how far was the burned wire you found ?
454cid
Loc: West Michigan
Reg: 02-18-12
11-28-18 08:04 PM - Post#2752739
I just read it... very interesting. My truck being OBD2, I wonder if I can see what the VSS reads directly.
99 K3500 RCLB
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
11-29-18 06:51 AM - Post#2752764
It was about a foot from the vss so I didn't have to go very far. I'm not sure if the computer monitors speed or not. That still wouldn't tell you where it is bad.
If I remember right, the first connection is right by the transfer case. Just make sure you have it good and sturdy before you crawl under it.
Jeff
Sabino
Reg: 07-16-05
12-02-18 09:02 AM - Post#2753089
I had problem where speedo was occasionally erratic & would rise when reving engine in park. problem was sensor in trans. Even though it was functional, signal level wasn't large enough/quality good enough that the VSS could detect reliably. Replaced it and problems went away.
net is just because there is a signal doesn't mean it's a good enough signal to function. Memory is both wires from sensor go to VSS (on my '93 -don't know about newer models), if so you could unplug sensor & VSS, jump connector at sensor and check continuity @ VSS connector.
Just replacing sensor to eliminate that as variable may be easiest/quickest
65 Belair 350
68 Camaro 327
85 Caprice 5.0L
93 Suburban 5.7L TBI
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
12-02-18 06:47 PM - Post#2753135
    In response to Sabino
There is no sensor in the transmission unless you're talking about the VSS on a 2WD. It is in the transfer case on a 4WD.
Jeff
Sabino
Reg: 07-16-05
12-03-18 07:05 AM - Post#2753164
Yes, my experience is with a 93 2WD. I assumed circuit for detecting speed would be same, just different location for the sensor. Is a 4WD different?, no VSS?
65 Belair 350
68 Camaro 327
85 Caprice 5.0L
Execution time: 0.1 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:38 PM
