 Page 1 of 2 ALL12
Username Post: Gas Tank Whistle ?        (Topic#354077)
2D51STYDLX
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
11-26-18 09:58 PM - Post#2752475
Is my 51 suppose to have gas tank whistle, if so and mine doesn't work can they be fixed ?
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
Chevs of the 40s
Dave in VA
Dave in VA
Loc: SW Virginia, USA
Reg: 03-11-18
11-27-18 04:56 AM - Post#2752485
    In response to 2D51STYDLX
Hmmm. Never heard of that, but mine does whistle while filling and I wondered why.
Sorta off topic, but is it better to store the car with a full or half tank? I'll probably start it every few weeks.
"Knowledge is Good" -- Emil Faber
U S Navy MM2 1970-75 USS Canisteo AO-99, USS Miller DE-1091 (The Champagne of Ships)
1950 Styleline Deluxe 2dr, mostly stock, driver quality...new to me 3/18
2016 Equinox LTZ
2017 Silverado LTZ 6.2
Edited by Dave in VA on 11-27-18 05:39 AM. Reason for edit: No reason given.
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
11-27-18 06:39 AM - Post#2752494
    In response to Dave in VA
My filler neck whistles too when the tank is nearing the full mark, (1/2 to 3/4 full). Figured out is air from the tank escaping through the breather tube. I thought it was because of modifications done to my tank and filler neck because of the fuel injection, electric fuel pump, and matching plastic, clicker style gas cap. Newer cars do not have this tube. I don't see why it couldn't be eliminated, but I haven't tried it yet.
Rumor is that full tank is better. As for short term storage, as in over the Winter, I believe you do your car no favors by starting it every few weeks. The engine and exhaust system don't get hot enough to burn off the condensation formed by cold starts, and remain in the crank case and exhaust system until it is driven for longer periods of time.
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. Remote door and trunk locks, GM cruise control, A/C,
Edited by johnwd98 on 11-27-18 06:49 AM. Reason for edit: No reason given.
Dave in VA
Dave in VA
Reg: 03-11-18
11-27-18 06:56 AM - Post#2752496
    In response to johnwd98
Thanks Very good info.
2016 Equinox LTZ
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
11-27-18 07:07 AM - Post#2752498
Hum...not sure if it can be fixed if it is not operating...or what exactly would cause it to not operate properly or at all. It was called Whistle Guard and either started or stopped whistling when you were getting close to filling the tank. I believe the filler area had changed to a more boxed in area and if the tank was over-filled led to the possibility of fuel spilling onto the lacquer finish and causing that streak you see many times from the filler flap. You might removed the filler and inspect it to see if you can see anything obviously amiss. I suppose someone also could have switched out tanks at some point and did not put a 1951-52 tank back in. I don't know if it this feature returned in '53 or '54.
Attachment: Whistle_Guard.jpeg (66.87 KB) 8 View(s)
1951 Fleetline
52BA
52BA
Loc: Newberg, Oregon
Reg: 04-12-06
11-27-18 08:15 AM - Post#2752508
Back before auto shutoff nozzels at the gas pumps
it was to let them know when the tank was almost
full ( the whistle would stop ).
Gary
11-27-18 01:53 PM - Post#2752551
    In response to 52BA
Gary
Exactly!
I bought my 51 from Granddad in 62, just before going to Nam. Back then it whistled------------and it still does. It has the original tank, filler tube, and vent tube with a genuine 51 cap.
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
11-27-18 06:37 PM - Post#2752571
The newer fuels with ethanol suck water from the air, so it's better to store with a full tank. It's also a good idea to add some Stabil when you fill up the tank.
Good luck with yours!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
11-28-18 09:30 AM - Post#2752646
    In response to mahlmann
The whistle was an option or standard? mine has it, and it hasn't failed me yet. The pitch is high, then gets lower, and stops. I have never overfilled the tank if I stop right when the whistle stops. 10,000 miles. To answer the OPs question, if its there but doesn't sound, I'd say start with visual inspection for physical damage or obvious grime, and clean with carb cleaner if its the latter, trying to avoid it all going down into the tank.
Winter storage... Full tank is best, non ethanol. Do NOT start it at all unless you intened to let it warm up and run for a good long while when warm. When a car starts and runs cold, condensation is all in the exhaust (and in the motor) and its particularly acidic becuase of combustion byproduct. This will rot out your exhaust in short order.
We have a 6 month winter (our second 12" snowfall is occurring now - 11/28! and we get them into April) and over the years, I have stored my car full with non ethanol, and only started it when I needed to pull it out move it, but when doing so, gave it like 30 minutes plus to enjoy being alive
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
drew1987
drew1987
Reg: 02-23-14
11-28-18 09:38 AM - Post#2752647
    In response to drew1987
also, in years past I have used Satbil but haven't the last few, partially because of forgetfulness but then in faith that the non ethanol helps.
Also, as terrible as it probably is, when we get a nice sunny winter day with dry roads, I usually take a 20 or 30 mile cruise. The photo shows a puddle and wet car tracks... its the parking lot, not the road. I usually wait until I see the roads dry a whole day in my work car, and if there is no rain or snow before I can get to my 50, I drive it.
Attachment: January_cruise.jpg (1.75 MB) 7 View(s)
Member:
RAM_51
RAM_51
Reg: 12-28-02
11-28-18 03:56 PM - Post#2752701
Standard equipment on both Special and Deluxe models.
1951 Fleetline
johnwd98
johnwd98
Reg: 09-05-10
11-29-18 05:22 AM - Post#2752755
    In response to RAM_51
I personally think the whistle was a design flaw that GM made the best of. Up until now I had never heard of the whistle being a safety feature. In fact I find it kind of embarrassing at busy gas stations. I'm the only one whistling. I don't care for that crazy whistle to draw even more attention . Last Winter, I rolled up a piece of window screen to try and disrupt the air flow, and stuffed it into the smaller tube, didn't change much. I may just remove and plug the noisy thing.
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
11-29-18 08:21 AM - Post#2752769
Dave,
If you have a lake nearby, or can get to a marina that sells gas, some of them still have leaded gasoline. Expensive, yes. If I were going to store it for a winter, I'd run it dry. Then put 5-10 gallons of leaded in the tank. Start it up and you should be good to go.
The unleaded mix they have now is really hard on the fuel pump diaphragm, and the seals on the carburetor pump.
Griff
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
DanD1950
DanD1950
Loc: London Ont. Canada
Reg: 10-16-11
11-29-18 11:01 AM - Post#2752789
Don't plug the vent tube; unless you enjoy taking an hour to fill the tank; along with a number of blow backs of fuel.
Dan.
50 Styleline Deluxe, 2 Door Sedan, Was a 216cu", Three Speed Manual. She now has a 4.8Lt V8 LR4 injected engine, 4L60E 4 speed automatic, 10 bolt diff 342 gear with an Eaton C80 Locker
Dave in VA
Dave in VA
Reg: 03-11-18
11-29-18 01:39 PM - Post#2752807
    In response to DanD1950
I gassed up today. Mid-grade, no ethanol. It whistled while filling, changed tune and stopped, then the pump cut off. I couldn't squeeze much in after that.
2016 Equinox LTZ
Danflem
Loc: Brisbane, Australia
Reg: 09-15-16
11-30-18 03:01 AM - Post#2752860
The wording in the 1951 Australian GMH owners manual reads:
"On Sedans, a whistle system is installed in the vent pipe. This whistle is audible until the fuel level reaches a point one gallon short of full capacity"
johnwd98
johnwd98
Reg: 09-05-10
11-30-18 06:12 AM - Post#2752866
Dan.
I wouldn't want that, but the vent tube and the filler tube are at the same level on the tank so, I don't know why that would make any difference.
johnwd98
johnwd98
Reg: 09-05-10
11-30-18 07:03 AM - Post#2752876
An after thought. When I was a kid, I had a 52 Bel Air, I don't remember that annoying whistle when filling the tank. It has been said in earlier posts that, that "safety" feature was only available on the sedans...I would think the more expensive Bel Air would have that "option" if were really an intentional safety feature.
2blu52
2blu52
Reg: 03-12-02
11-30-18 07:26 AM - Post#2752881
  • johnwd98 Said:
Dan.
Stop and think what the vent tube is doing while you are filling the fill tube with gasoline!
THOMAS JEFFERSON
drew1987
drew1987
Reg: 02-23-14
11-30-18 10:23 AM - Post#2752899
    In response to 2blu52
Off topic but related, would parking my '50 (no gas leaks, stock tank) in a basement of a house make the house smell like gas? i have to imagine it would as there is no means of capturing vapor...
Member:
Edited by drew1987 on 11-30-18 10:23 AM. Reason for edit: No reason given.
2blu52
2blu52
Reg: 03-12-02
11-30-18 03:54 PM - Post#2752929
Yes!
THOMAS JEFFERSON
one4dad
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
11-30-18 05:06 PM - Post#2752938
I see 2blu's answer, but growing up in Pennsylvania and West Virginia our garages were under the house. It was separated from the rest of the basement, but there were rooms above the garage area. We did not notice any smell of gasoline, etc. but I tend to agree that some smells would be present.
Bill
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission.
2D51STYDLX
2D51STYDLX
Reg: 03-03-11
11-30-18 10:27 PM - Post#2752958
I would think gas fumes would stay along the ground.
Roger
John Prine
johnwd98
johnwd98
Reg: 09-05-10
12-01-18 06:34 AM - Post#2752970
Ya, ok, removing the vent tube is not a good idea. But, the whistle has got to go Haha! It's down a ways on the to do list, hopefully, with a little thought, it will be an easy "fix". I have major engine work that has priority for the time being.
2blu52
2blu52
Reg: 03-12-02
12-01-18 07:13 AM - Post#2752973
I guess I missed the location of the garage but with my wife it would not make any difference at all. She can smell gas fumes from just about any where. Me, I burned my nose out years ago
THOMAS JEFFERSON
schudaddie
schudaddie
Loc: SW, MI
Reg: 10-31-01
12-01-18 09:31 AM - Post#2752987
I threw mine out accidentally when I installed a new tank. I wish I could somehow fabricate a new one to install in the rubber vent hose. this would be easy to do but I'm just not sure how big the small hole is in this whistle. so if anyone is doing away with theirs please get some dimensions and post what they find so I could get mine whistling again.
thanks in advance, bill
drew1987
drew1987
Reg: 02-23-14
12-03-18 10:13 PM - Post#2753285
    In response to schudaddie
Yea not cool. I just wondered because my wife and I had chatted about a finshed basement (drywall, wood/carpet flooring, drop ceiling) with the chevy right in the middle becuase, why not? she was down with it... shame it wouldn't work out. There goes one of my better crazy ideas up in smoke.
The whistle... see about filling your tank 10-20 times before removing it. it is quite handy...
Member:
johnwd98
johnwd98
Reg: 09-05-10
12-04-18 06:51 AM - Post#2753302
Bill, not sure what you mean, but here goes, I'm pretty sure that there is no whistle installed in the vent tube. Like I said before, just a design flaw in the way the tube curves, and attaches at the filler neck that makes it whistle.
schudaddie
schudaddie
Loc: SW, MI
Reg: 10-31-01
12-04-18 04:11 PM - Post#2753374
When I had my old tank removed I seen a piece that looked to be pressed into the vent tube and if I were to guess, the hole was 1/8" diameter. I figure If I were to machine something to fit as close to the tank inside the rubber vent hose it might recreate the whistle sound. So if someone here were changing their tank and could verify this it would be very helpful.
later, bill
johnwd98
johnwd98
Reg: 09-05-10
12-05-18 06:07 AM - Post#2753446
Where was the piece with the 1/8" hole pressed into? I've had my tank and filler neck out more than once and never noticed anything like that, but then I wasn't looking for something like that either.
Chevs of the 40s
 Page 1 of 2 ALL12
Execution time: 0.094 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:37 PM
