Username Post: 56 wont charge        (Topic#354049)
stevea54
stevea54
Loc: dc
Reg: 05-13-13
11-25-18 10:23 AM - Post#2752306
hi fellas been away from working on this car for awhile due to injury had probloms with dash wiring put in a new battery and alternater now car will not charge ? also wanted to ask can you use an idler bearing kit with power steering thanks steve.
11-25-18 12:44 PM - Post#2752317
    In response to stevea54
What type alternator, internal or external regulator? Why did you change the alternator? Was it charging before you changed it? What is the voltage at the alternator output terminal with the engine running and without it running? Does the "gen" light stay on?
I'm pretty sure you can use a bearing kit in the PS idler arm, but why would you want to?
Edited by acardon on 11-25-18 12:46 PM. Reason for edit: No reason given.
stevea54
stevea54
Loc: dc
Reg: 05-13-13
11-25-18 09:36 PM - Post#2752367
    In response to acardon
it is an internal regulated alternater checked with voltmeter only got a reading of 11.5 volts the old artenater was bad pretty sure gen light does not stay on I pulled the cluster taking wires off the ignition switch with a volt meter on still no charge should the car stop running when the pink acc wire is pulled from ignition switch? don't think it should thanks steve.
11-26-18 08:21 AM - Post#2752396
OK, does the gen light come on at all? The gen light connects to #1 terminal of the alternator and "excites" the alternator to start it charging.
No, it shouldn't die when the pink wire is disconnected from the ignition switch.
stevea54
stevea54
Loc: dc
Reg: 05-13-13
11-26-18 04:28 PM - Post#2752452
no problems with gen light think I might have to replace dash harness and after market ato fuse panel thanks for responding steve.
Execution time: 0.087 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:06 PM
