Username Post: Plugging firewall        (Topic#354039)
Frankman
Frankman
Reg: 09-25-17
11-24-18 04:16 PM - Post#2752271
I'm thinking I should plug the throttle body hole. I'm also welding the holes to battery tray since I am going to put the battery in the trunk. So are there any other holes I should get rid of since I'm going to a FI engine.
11-25-18 07:33 AM - Post#2752296
    In response to Frankman
What's a throttle body hole? What are you using for a throttle pedal? Are you keeping the original wiper motor? Are you adding A/C? Are you using the original type firewall pad? Lots of holes you can get rid of if you want to smooth the firewall. Link to firewall holes.
Frankman
Frankman
Reg: 09-25-17
11-26-18 08:08 PM - Post#2752473
    In response to acardon
Wow I'm impressed that is very nice, yes I'm trying to smooth it out as much as possible. I am going to add a/c, still trying to decide on the wiper motor. Moving the battery to trunk. Thank you for your response. Oh what I'm calling a throttle body hole is where the linkage goes thru the firewall to the gas pedal.
11-27-18 07:28 AM - Post#2752510
That will depend on the pedal you use. Some pedals use the original hole to mount the pedal and you drill another hole for the cable.
Execution time: 0.056 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:47 AM
