Username Post: 2013 Equinox 3.6 carbon build up        (Topic#354018)
bolake
Loc: Northern MN
Reg: 09-05-17
11-22-18 06:42 AM - Post#2752098
Have 2013 Equinox 3.6 V6. 52000 miles well
maintained, oil/filter change every 3000 miles. Run perfect one minute wouldn't start next. Took to GM dealership code showed timing chain, when dis-assembled time chain and guides all OK, valves were stuck open from carbon build up. Service manager said never seen anything like it , rest of internal motor was very clean. Has anyone heard of anything like this or what would cause carbon build up with only 52000 miles?
If your not the lead dog the view never changes
11-22-18 02:17 PM - Post#2752134
    In response to bolake
This seems to be a common problem if the engine is direct injection, but not at such low mileage, which GM knows all about, or bad valve seals. Check this thread. https://www.equinoxforum.net/10-general-tech-secti ...
Edited by Shepherd on 11-22-18 07:43 PM. Reason for edit: No reason given.
bolake
Loc: Northern MN
Reg: 09-05-17
11-23-18 01:46 PM - Post#2752208
Interesting, thanks for the information
Execution time: 1.087 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:49 PM
