Username Post: no power?        (Topic#353953)
jophes72
Loc: Huntington Beach CA
Reg: 07-19-16
11-18-18 08:39 AM - Post#2751692
Ok , I can start my truck and rev engine to 3500 rpm ,It sounds good but when I put it in gear it wants to die. If i take my foot off pedal it will die. I did however get it to drive. It would not go over 5 mph and rpms would not increase.maybe 1000. Any ideas. I could floor my pedal and thats all I get. Then when I put it back in park it wont really rev up like at first. Thank you. Later when it cools down it seems to start up and rev fine. with same . actually i just started it up and its acting like results if i put it in gear. New carb ,hei, fuel pump. I have been having a misfire in my system and now this is happening . thanks.
Edited by jophes72 on 11-18-18 09:40 AM. Reason for edit: No reason given.
jophes72
Reg: 07-19-16
11-18-18 12:48 PM - Post#2751708
    In response to jophes72
Now it will not start again. It seems whenever I have reset hei on tdc. It will fire right up . Then later I get nothing. Cranks turns over fine kinda starts for a second and dies.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
11-19-18 11:07 AM - Post#2751783
have you checked the exhaust system for restrictions?
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
jophes72
Reg: 07-19-16
11-20-18 08:29 PM - Post#2751971
    In response to 62chevy427
mufflers seem to be working fine
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
11-23-18 01:09 PM - Post#2752203
What trans are you running ? is the lockup working proper on an automatic.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
64ss409
Reg: 12-04-02
11-24-18 10:28 AM - Post#2752258
Are you setting the timing on 0 with no initial advance? Is your vacuum advance disconnected when you set your timing? I ask because it sound like possibly retarded timing.
Ron
jophes72
Reg: 07-19-16
11-26-18 09:11 AM - Post#2752399
    In response to 64ss409
Could I be 180 out on hei?
doubleE
Loc: Eagan MN
Reg: 06-02-03
12-04-18 05:53 PM - Post#2753385
If everything else checks out you might suspect Timing chain/gears may have skipped 1 or more teeth due to wear. Pull the timing chain cover to check.
dave5287
Loc: ny
Reg: 04-12-13
12-05-18 04:41 AM - Post#2753434
    In response to doubleE
any chance your hei is not getting 12 volts constant voltage or have you checked fuel pressure from lines mine had restriction in fuel line and also after start up volts to hei went from 12 volts to 9 volts constant had to hook up a 12 volt power wire to straight 12 volt power
1967 chevy c20 1968 gmc c2500 1969 gmck2500 1972 chevy k20 1964 chevy impala
bry593
Reg: 10-07-13
12-14-18 09:18 AM - Post#2754489
    In response to dave5287
If that is a brand new, aftermarket HEI, I recommend disassembling and soldering every connector. The factory crimps are done poorly, and will sometimes make contact, and sometimes not depending on which way the wind is blowing.
Execution time: 0.17 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:22 AM
