Username Post: A body rear control arms        (Topic#353935)
Am4wag
Reg: 11-19-15
11-16-18 05:03 PM - Post#2751560
Since putting a big block in I can really feel the shot bushings in the rear control arms.I'm thinking a complete arm assy.w/new bushings.Anyone familiar with something like this/comparable?:
http://umiperformance.com/catalog/index.php?main_p...
The bearer of gossip is a small untrustworthy person who takes delight in someone else's problems. Avoid them.
Let's all make the day count. - Charlie Daniels
Edited by Am4wag on 11-16-18 05:04 PM. Reason for edit: No reason given.
11-16-18 08:21 PM - Post#2751573
    In response to Am4wag
That’s pretty pricey. You could replace your bushings and weld steel plate to the bottom of your existing arms to box them for far less.
1957 Cameo Carrier
11-19-18 10:08 PM - Post#2751863
i would shop around more. as noted you can beef up stock arms. i run stock modified arms and have had a few problems with them. the metal is thin so the bolt holes in the upper arms can wallow out or just rip out. the bushing shells can wallow out in the holes too. you can weld the shells in the arms if using slip in bushings. if you buy aftermarket arms make sure you can get replacement bushings. i got delulum front bushings and cant get replacement inserts. im gonna make my own. if i get enough time im gonna invent my own 3 link rear arms. if i get money im gonna get irs. haha, in my dreams
55MAS
Loc: North Coast, USA
Reg: 12-19-01
11-21-18 02:58 AM - Post#2751984
    In response to wagonman100
El Caminos never had boxed lower control arms nor F41 with any engine, including the top option, LS6. Just saying that GM never thought they were required. For a driver new bushings are sufficient. Drag car is something else.
Execution time: 0.116 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:51 PM
