Username Post: new electric problem        (Topic#353918)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
11-15-18 09:02 AM - Post#2751464
2000 S-10 Blazer. I have had a battery drain problem for a long while. I put a battery shut-off switch on the ground post. which saves the battery.
now a new problem. the Blazer just dies. all the lights on the dash comes on, the radio clock goes back to 1:00, which means [I think] a major disconnect. it will start right up, but the radio, being off, makes noise [remember in the old days when the AM radio had spark plug wire noise and sounded like an audio tach!] ya it's like that.
when I got home, radio noise still happening, I pulled the radio fuse, which stopped the noise, but all the dash gauges quit working [so I cant do that].
I have cleaned the battery terminals, and the cable to engine ground. today [after it warms up]I am going to ck. the + cable at the starter.
is there a ground wire under the dash? if so where? is it possible to find the hot wire to the radio [not much room under the dash to see anything]
I cant drive this anymore as it is unreliable.
any thought will be appreciated.
thanks Rod in AZ
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
11-15-18 11:17 AM - Post#2751480
    In response to rod
Be sure to check the grounds on the back of the heads....often overlooked.
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
rod
Loc: kingman,az
Reg: 04-29-00
11-18-18 09:49 AM - Post#2751698
    In response to SleeperSS
I had previously put a battery disconnect on the battery. I checked it yesterday. the knob tightens the two parts together. as it was, there was a high point, which was all that was making contact. a far amount of arcing on that. so a bit of file work and I added a brass washer to make better contact. havent tried it yet. maybe Tuesday.
will post an update after that.
Rod in AZ
11-18-18 10:37 AM - Post#2751702
    In response to rod
There's a short somewhere. Problem is finding it. Wiggle the harness. Especially around the passenger side head. I've seen a few harnesses rubbing against the head or brackets.
'08 GMC Acadia 3.6L SLE
rod
Loc: kingman,az
Reg: 04-29-00
12-25-18 09:53 AM - Post#2755553
so I filed the contact point on the disconnect and added a new brass flat washer. I have driven it 130+ miles now, and it runs fine. so the problem was lack of good ground side contact. I will just have to live with the battery drain. I was told that the stepper motors, somewhere, are the problem. the money to fix it are just not worth it.
more new car cheap junk.
Rod in AZ
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
12-25-18 01:35 PM - Post#2755570
    In response to rod
Rod in AZ
Told by who? Start pulling fuses one at a time to isolate which circuit is the problem, and start from there.
'96 S-10 SS
'02 BlaZeR2
rod
Loc: kingman,az
Reg: 04-29-00
02-11-19 07:06 PM - Post#2759675
I had previously pulled all fuses. the problem lies with the radio. when that fuse is pulled the dash gauges go dead. that wont work. some day when it is warm, I am going to try to find the power wire to the radio and disconnect it. the radio, when OFF, makes a noise like an audio tachometer. I am going to bet the wire cannot be found, as there is no room under the dash.
I am going to try the shop that sells high dollar radio/speaker installs. maybe they will know.
Rod in AZ
02-13-19 05:26 AM - Post#2759797
    In response to rod
Pull the radio. Unplug it. Leave it unplugged and drive it. With adapters, you can replace the radio. I installed Pioneer stereos in both my Jimmy's. Even installed XM radio on the '95.
Execution time: 0.078 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:08 AM
