Username Post: 1975 C30 Fuel Tank Diagram        (Topic#353890)
Thumpit
Thumpit
Reg: 11-26-16
11-13-18 11:02 AM - Post#2751272
Going to change out the fuel tank and sending unit as well on my 1975 C30 flat bed. Tank is on the passenger side. Gauge used to work until gas fell below 1\2 a tank, then it showed 1\2 till you ran out. Doesn't work at all now. Plus i took the tank off once to clean it and do a small hole repair and did not hook any of the wires back on the tank. Tired of leaking tank and no gauge. So I order a new set up.
Does anyone have a wire diagram for hooking up the sender with the wire or wires under the cab? Cant be over two or three. I don't remember.
Thanks for the help
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
11-13-18 05:17 PM - Post#2751309
    In response to Thumpit
Purple goes to gauge and black to ground, thats it.
Senior Chevytalk Moderator
11-14-18 05:18 PM - Post#2751414
    In response to junkman104
Go here and download a factory manual for your truck.
http://forum.73-87chevytrucks.com/smforum/index.ph...
Thumpit
Thumpit
Reg: 11-26-16
12-03-18 01:26 PM - Post#2753210
The single wiring plug that snaps down the sending unit is missing. Does anyone still make that end of the wiring connection or is there a way to make a connector that will work well. On the sending unit is just a single pole that the connector would attach to. I couldn't find an old truck to get one off.
Edited by Thumpit on 12-03-18 02:01 PM. Reason for edit: No reason given.
12-03-18 03:19 PM - Post#2753225
I have not looked at a fuel sending unit in years. Can you post a pic?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
12-04-18 05:37 AM - Post#2753298
https://www.ebay.com/itm/Gas-Tank-Fuel-Sen ding-Unit-Pigtail-Wire-Ha rness-Connector-A-C-Compr essor-Chevy-/302628787151
12-04-18 07:14 AM - Post#2753306
Nice find. Eventually, I'll need to replace on unit on my truck. One tank reads off by a little.
Thumpit
Thumpit
Reg: 11-26-16
12-04-18 08:15 AM - Post#2753315
Thanks.
The guage has always read from full to 1/2 a tank and then stopped at 1/2 a tank on the guage. I put a new tank and sending unit. I made a temp connector and hooked it up and the guage is still on 1/2 though the tank is empty right now.
Not sure if the guage need recalibration or fuse is blown.
Is the 'cluster fuse' where the guage gets it power?
I probably need to use a meter to check wires too but not to sure how to operate one.
Thanks again
12-04-18 09:13 AM - Post#2753324
Did you download the factory manual? I think it has ohm readings for level indication.
Thumpit
Thumpit
Reg: 11-26-16
12-04-18 10:24 AM - Post#2753333
I could probably find the readings on line. But with a meter I would like to test the hot wire (which is a 18 Tan according to my 75 wiring diagram) to check for power at the tank.
Would it just put the Hot lead on the Tan wire Connector and ground the Neg to the frame? And then put the settings on Oms?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
12-04-18 05:05 PM - Post#2753378
The sending unit is the ground. Shorted to ground the gauge should go past full.
Thumpit
Thumpit
Reg: 11-26-16
12-04-18 07:09 PM - Post#2753394
Thanks for the help. Im probably doing this all the hard way but will know better the next time.
Thumpit
Thumpit
Reg: 11-26-16
12-07-18 07:42 PM - Post#2753810
Thanks for the tips. Got here working again.
Execution time: 0.118 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:29 PM
